Question about GE Monogram Side by Side Refrigerator
Ge monogram fridge makes a knocking noise when freezer door is opened and then after closing
TheMobilian
  • 8220 Answers
SOURCE: GE fridge doors open and close
Raise the legs up on front till the machine tilts slightly towards the wall. The weight of the doors will then be shifted towards the machine instead of away from it. Only a slight adjustment is needed and should have been done by the delivery guys. A $5 tip would have gotten that done, you must be a cheapskate.
Source: I used to deliver them before I learned how to fix them. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 14, 2009
SOURCE: GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Posted on Jun 11, 2009
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
caroldon
  • 17130 Answers
SOURCE: Gr Side-by-side refrigerator freezer makes noise when door close
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
Posted on Jul 31, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Ge monogram side by side freezer is at -5 fridge
If you are showing a frost pattern iside the freezer and higher temperatures in fresh food compartment that is a sign of defrost failure. What is happening is the airflow to the fresh food section is being restricted by a large blok of non defrosted condensate behind the rear pane you see the frost pattern own. I am sending a manual if you like to follow along and ask questions but as I see from your discription this is what most likely happening. Your model does defrost cycle through the motherboard and has no defrost timer. So the most likely cause is you Defrost heater or defrost thermostat are defective. Here is the heater and instructions on how to test heater Click Here=> WR51X322 Heating Element and Defrost Thermostat=> WR50X10088 Defrost Thermostat
Here is the service manual=> GE Monogram Refrigerator Service Manual
You can find those two part numbers here also=> WR51X322 Defrost Heater
and Defrost Thermostat Here=> WR50X10088 Defrost Thermostat
Should you have any questions I will be here to assist you or on my sites, Thank You Sea Breeze
Also make sure none of the lower vents are closed inside fresh food compartment that will also restrict airflow. Manually defrost ing the freezer will give you about another week to resolve this problem should it turn out as defrost problems. You will need Adobe Reader to open the manual I sent you=> free download.
Posted on Oct 15, 2011
GE Monogram refrigerator feeezing even when thermostat is set at 45
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 07, 2010 | GE Monogram Side by Side Refrigerator
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
I have a monogram ZIS420 the freezer works fine
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Freezer door is canted forward. This separates the gasket from the frame and allows air in. Large amount of frost build up.
HI thanks for the question. the fridge door should close by itself if opened and then just let go of door. if not that way. raise the front of the fridge to make it work that way. thanks the appliance doc. please rate my answer. thanks.
Aug 11, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerator warm, freezer too cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram Side by Side Refrigerator Logo
44 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
