Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Cleaning Taking it apart to clean the dust out
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Blowing dust out even after cleaning filter
the bagless containers of these vacuums do tend to hold a strong dust odor. the only way ive found to help eliminate it is with a product that i use called FreshWave odor neutralizing pearls. you never want to use fine dust carpet freshener or any product like that cause it will eventually burn up your motor. but if you are interested give me a call and i can ship you some of the freshwave. 703-724-1112
Apr 11, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Took apart my electrolux 6500 sr. How do I get my fan shroud off to clean the blades? Thank you.
Oops. Don't. First blow it out with another canister vacuum or air hose. That's usually sufficient for removing dirt and dust. For dust/dirt in the motor, use a motor cleaning spray that can be picked up at most auto parts stores. One that evaporates quickly and doesn't leave a sticky residue. One's called Electric Motor Contact Cleaner by Gunk (http://www.gunk.com/CAT_NM1.asp). There are others.
Hobby shops may also have one available called Dynamite Magnum Force 2 Motor Spray.
It shouldn't be that dirty unless someone has been using generic "made to fit" Electrolux bags. Or if water or other liquid has been vacuumed, resulting in rust, etc.
Keep in mind that reassembling the vacuum is more difficult than taking it apart. If not done so correctly, various problems may result. While you have it apart, it would probably be a good idea to use pipe cleaners to clean out the tubes connectiong the "control valve assembly" to other parts of the vacuum. Also, unscrew the knob at the top of the "cva" to check for wear and breaks. Clean dust thoroughly from all interior parts.
Oct 05, 2010 | Electrolux Epic 6500 Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
How do you clean the Dyson dco7 cyclone top
Hi its Darran at Dyson.
We would not recommend that you take the cyclone top apart. This part is designed to be a sealed unit and taking it apart may affect ther performance of your machine ongoing.
If you are concerned with the performance of your machine, please follow the blockage procedure and filter washing instructions on our website in the support section at www.dyson.com or check your user guide.
If you do want to clear dust and debris from the cyclone, we recommend that you simply hold the cyclone top over a bin and bang the sides gently to remove any dust from the inside.
Kind regards
Darran
Dyson Customer Service
Mar 16, 2010 | Dyson DC07 All Floors Bagless Upright...
Motor noise CV 353
its not that bad to take apart and blow out the motor with a compressor, but if that dust got into the bearings of the motor it could be ruined.
Apr 19, 2009 | Broan-NuTone CV353 Central Vacuum
Roomba Pro Elite
The electronics have failed most likely. Not uncommon. If it is within the warranty period call the company ( good luck with that ) and they will send you a new one. These machines are not designed to be repaired other than brush replacement and filters, dust containers, etc.
Jun 11, 2017 | Roomba Pro Elite Bagless Robotic Vacuum
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
16 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
