Question about Jenn-Air M170 Microwave Oven
Can anyone get a hold of the Jenn-Air Microwave M170W Button to open the door (Part# 56001009)Mine cracked and the part has been discontinued. Thank you.
  • fgoodman Jun 24, 2009
    No I haven't but I'll give it a shot. I cannot locate the discontinued part anywhere.
  • William Miller
    William Miller May 11, 2010
    Have you tried repairing it with two-part epoxy such as JB Weld?
    New Friend:
Same thing happened to me. I couldn't find a replacement part, but I was able to make a fairly easy functional repair. If you take off the microwave cover, you can reach the back side of the control panel where the door release button is located. With a screwdriver or your finger, you press down on the top attachment tab (it's the swivel point that holds the button in place) with just enough pressure to remove the button. You'll have to do something similar to remove the other half of the broken button. If the two pieces of the button fit neatly together, then you can epoxy a piece of flat metal or rigid plastic to the back side of the button in order to join the two halves. Be sure to clamp the two halves of the button tightly together while the adhesive sets to get a tight fit and minimize the crack line. Let it cure, then replace in the microwave. It's not cosmetically perfect because there is still a hairline crack in the button, but it's not that visible and the button works well. I can't say yet how long this repair will hold up yet. I suppose that will depend on the quality of the bond you achieve when repairing the button. Good luck.
Posted on Nov 24, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: 1997 Jennair microwave M170W
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: replacing outer glass and stainless steel door on my jenn-air microwave oven
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 01, 2008
  • 212 Answers
SOURCE: microwave exhaust door stuck in open and close cycle.
Depending on age You might need a new one. A repairman might be able to fix it.
Posted on May 24, 2009
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
W2400 jenn air microwave door latch broken door will not open
If you wish to get some details about microwave oven; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 15, 2016 | Jenn-Air Microwave Ovens
Microwave makes noise after door is opened jenn air model jmv9169ba
Microwave ovens emit powerful radio waves and in general for safety reason should only be used when in perfect working order. It usually costs more to repair an older microwave oven than to simply replace it.
Suggest buy a new one.
Mar 02, 2018 | Jenn-Air JMV9169BAS Convection Microwave...
Jennair Microwave Shuts Off after 3 seconds
This is usually a defective or loose bottom door switch or that switch's mount is loose, misaligned or broken.
It's usually caused by opening the door while it's cooking instead of hitting "stop" first) or slamming the door or both.
My help file on door switches is here.
May 19, 2013 | Jenn-Air JMV8186AA Microwave Oven
Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
Apr 20, 2010 | Jenn-Air JMV8166B 950 Watts Convection /...
Microwave exhaust door stuck in open and close cycle.
May 24, 2009 | Jenn-Air JMV8166BAS Microwave Oven
Need Replacement Plate
Look on the internet auction sites (ebay etc)
There is quite a trade in them. Make sure match the dimensions of yours before purchase.
Jun 11, 2008 | Jenn-Air JMC9158AAS Convection/Microwave...
Jun 07, 2008 | Jenn-Air Microwave Ovens
Jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Mar 24, 2008 | Microwave Ovens
Open Questions:
See all Jenn-Air M170 Microwave Oven Questions
Microwave Ovens Logo
165 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
