Question about Breville ESP8XL Espresso Machine
My breville espresso machine steamer not working
The light stays blinking and making noise but the steamer doesn't work. Water does come out of the wand if I change the setting but no head
2 Suggested Answers
  • 7 Answers
SOURCE: I have a Breville ESP6 Espresso Machine which
The wand is relatively easy to remove. Thing is whether you have the right tools. If you can find stubby phillips and flat screw drivers, the job will be much easier.
You first have to remove the trim that surrounds the pod and where it covers part of the wand.
The wand is held down by a flat-headed short screw. It might take a few tries to remove this screw due to calcification over the years. Once removed, the wand should just slight out. Check if the o-rings need to be replaced as well.
Posted on Mar 18, 2009
Mr Coffee Pump Espresso machine not working. Lights alternately flash between coffee and steam icons, machine makes noise, but coffee does not brew, water does not flow, steam does not come out.
The espresso portion may be clogged with hard water deposits, and the steamer tube with casein. Run a tank of plain white vinegar a couple of times then run a couple of tanks of plain water to flush the vinegar, Open the steam valve while the espresso portion is running and set the steamer pot under the steamer. Don't be surprised if a long white tube of hard white material slides out of the steamer valve. That's the casein, actually a form of organic plastic.
Sep 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
My Breville Expresso machine does nothing when I turn dial to make coffee
Sounds like its time to clean it. Run white vinegar and a little water through it.
Apr 18, 2012 | Breville Coffee Makers & Espresso Machines
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Why does the pump make a knocking sound when using the steamer
The steam is hitting water somewhere in the tubing....this is not a problem... it's just the natural reaction that happens when very hot steam hits cooler water...
heatman101
Apr 17, 2011 | Breville ESP8XL Espresso Machine
Doesn't heat the water Start...makes noise, the
the flashing heating light indicates that it isn't getting water. This could indicate that your pump has gone bad.
Oct 15, 2010 | Breville Die Cast 800ESXL Espresso Machine
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Steamer
Take off the edge on the steam pipe, clean it and mount it again.
/Mirran
Aug 31, 2008 | Breville ESP8XL Espresso Machine
No coffee
Does it come out water from the steamer?
if that is the case I would clean the filter on the machine.
Jul 16, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
60 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
