Question about Canon Office Equipment & Supplies
I have scanned a word document and now I can't figure how to use OCR to edit and save the document. I need a step by step answer. Thank you, Bill Garbo
    Sergeant:
  • 199 Answers
For ocr to edit
use software lise sprint 5.0 fine reader
it's very easy to operate.
and scan in JPG format for editing
Posted on Jul 09, 2009
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
I need to copy a word document however when I scan it, it makes it into a jpg document. What can do I fix this in order to be able to edit and save the scanned document as a word document?
Make sure you installed the full software suite for your scanner. Scanners do scan to image files but should come bundled with Optical Character Recognition (OCR) software. Select the OCR option in your scanner settings and it will convert your scans to an editable format. Take note, OCR software is only as good as the scan, and the content on the paper, so it might make some mistakes, in which you will have to manually fix in Word etc "proofing"...
Regards, Chris
Jun 29, 2011 | Fujitsu fi-6130 Flatbed Scanner
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
After I scan text, I cannot put it into a Word document, edit, or anything. I have an Epson 2400. thanks I do not have the scanner directions.
In order to scan to word so a document is editable you need to use Optical Character Recognition Software (OCR). You can download free ocr software from www.simpleocr.com Use that software and then either export once scanned to Word or Save as a Word document in the OCR application.
Jan 22, 2010 | Epson Perfection 2400 Photo Flatbed...
I don't know how to scan a document, save it to my computer, work on it and save it again for future use. How do I do that?
You have to install some kind of OCR (optical character recognition) software.
Usualy you will have CD with one of those in the box of your printer, but if you
do not have it, then go to this webpage and download ptogram for OCR.
Basically, OCR program will scan your document, convert it to electronic document
(word, text...) which you can then edit, modify, save and print.
Here is the link to FREE OCR software:
http://www.simpleocr.com/Download.asp
Good luck,
Dr. Milan Cankovic
May 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
Help with editing scanned document on microsoft word
you need to install a OCR software or an adobe photoshop software.
Jul 31, 2008 | HP PSC 1350 All-In-One Thermal Printer
How do i scan documents and save them in word ready for printing? how can i edit the saved documents? how can i enhance the quality of the documents? thank you
for scanning plz open my computer and open the scanner icon then follow the instructio.
for editing the scanned document you have to use a OCR software
Jul 03, 2008 | Office Equipment & Supplies
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
171 people viewed this question
old marine
old marine
