Question about Canon PIXMA MX310 All-In-One Printer
Help printerMX310to find were the hook up to the tower
Printerer MX310 will not print help?
    Genius:
  • 1,018 Answers
Did you follow the installation instructions and unlock the scan head? Don
Posted on Jun 23, 2009
How can the Canon MX310 be connected to a wireless network?
This model printer was not equipped with wireless capability, so you can't connect this to a wireless network without some extra hardware. (Canon's support page for this printer is here where all the features are listed.)
What you'll need is a USB print server that provides the link from the printer to the network. You can get a wired type like this one, which hooks to one of the wired ports on your router. You can also find wireless servers if the printer isn't located conveniently. Then the printer can be anywhere within range of the network, just like any other wireless device.
Hope this has helped. Thanks for using Fixya!
Oct 26, 2010 | Canon PIXMA MX310 All-In-One Printer
I have the printer hooked up to the desktop computer but it still says it is offline and will not print. I am using the USB cable that came with the printer, no printer cable.
Is it the printer or the computer that says it is offline. Has the printer been plugged into power and powered on ? Does the printer have a driver for the Canon MX310 ? What OS are you running ?
Oct 16, 2010 | Canon PIXMA MX310 All-In-One Printer
Trying to change from black and white printing to color on canon mx310 please please help
Go to Cannon My Printer file, Click Printer Settings, Click Maintenance Tab, Click Ink Cartridge Settings, Select the ink cartridge for printing, Hit ok.
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
I want to print user manual for canon mx310 now , needed urgently, selling floor model printer and manual is missing
Go to:
Canon MX310 Support
Make sure the Drivers & Downloads tab is selected. The guides/ manuals are listed for download. There are 2 pdf files and an exe on-line manual.
Open them and print.
Thanks for using Fixya.
Sep 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MX310 rubber track pulling ink fell off
there is no rubber track that pulls the ink cartridges, i think you are talking about the timing **** that sits directly behind the print head, you need to remove the covers so you can get to the carriage unit and the timing **** is just hooked on one end and on the other it is help on with a spring, its not that hard to put bak on once you work out how to get all the covers off
Jun 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
Mar 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't Scan with MX310 hooked up to Time Capsule
If you mean you connected it to the airport, that only supporting printing, not scanning. Have to plug it into the computer.
Jul 02, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
