Question about Dryers
How to fix
Ceq8858eq0, no movement
I just got a radford exchange purr-fect moments kitten cuckoo clock and the clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird sounds unit of th
There are several companies that sell that movement , just google clock movements and they have a chart with spec to match yours. I have replaced several in my time, its pretty easy
Jan 05, 2015 | Watches
Clock movement not working
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling.
http://usedclockparts.com/8-clock-movement-repairs/39-how-to-easily-clean-and-or-fix-your-clock-movement
Jul 07, 2014 | Seiko Mantel Clock
Cannot get pendelem to work
Feb 14, 2014 | Home
Keeps stopping
Sep 07, 2013 | Howard Miller Westmont Oak Yorkshire...
I have 10 year old Seiko wristwatch and the hour hand does not move. Can I fix ?
no if the hour hand is stuck then it will be the movement that needs cleaning and repair. It is probably the wheel that has broken. You will need a watch maker to look at it , they can replace the movement for around 45 dollars I think for this movement . If it can be fixed it would be cheaper.
Oct 20, 2010 | Bulova Watch
Just bough a Subaqua Noma III Chronograph Watch and the Day of the week...where it says mon tues etc...changes at 3 am instead of at midnight. how can i fix this
you cannot fix this. Unfortunately for movements to be that exact they cost a lot of money and the movement inside your subaqua is not that high tech and accurate. This is what makes watch really expensive the little things like this. Unless you are buying a 10k watch , they usually are not going to have the top of the line movement . The movement you have in your watch is an ISA 8173 and that is as accurate as the watch will get.
Oct 19, 2010 | Invicta Subaqua Noma Iii S
Citizen eco drive watch movement E870 date window out of synch
If the movement is broken, you can play around yourself; but you will need very fine tools. May be complex. Send an email to Citizen, they are very supportive. Look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Mar 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Dryers Logo
15 people viewed this question
Top Dryers Experts
