Question about Coleman Powermate 200 Watt Compact DC/AC Power Inverter # PMP
My pmp400 beeps constantly
Beeped ground fault light on since the day i bought it with the engine running even
2 Suggested Answers
stewbison
  • 577 Answers
SOURCE: I have a coleman powermate
Hello, the answer is no. This inverter will work with a pump that below or about 400 watts power for operation. I notice it says that the inverter 400w/800w. The 800 watts is the surge required to get an electric motor to run. On a single phase motor (120 AC) and it take 4 amperes to operator this motor. But to start the it will 12 amperes to start it. This is one reason why on a lot of electrical motors there will be a big tube or can, this is the starting capacitor, it stores energy in form of current (amperes) to drop across the windings of the motor when it starts. If some electric motors didn't have this capacitor. The most likely scenario would be tripping a breaker because it drawing to much current.
Now, for you problem. Example of Power and the unit of the formula is V (volt), R (resistance) I (current) P (power) Ohm's states that :
Now Power would be stated: P = V times(x) I. Therefore in your case, if the pump at normal operation is drawing 4 amps of current for operation pumping water. The power factor would be 120 V AC (house voltage) times (X) I (current) which 4 amps. So here is what you have: P = 120 X 4 equal= 480 watts.
Therefore, your inverter will not work because it operating at 80 watts more than the power inverter can deliver which is 400 Watts.
If you need to purchase a new power inverter, remember always take into account the Amperes required for operation. Just by the simple Ohm's Formula. Best of Luck. GB....stewbison
son
Posted on Aug 27, 2011
My Chrysler 200 year 2015 keeps making a short constant beeping sound when starting and after a couple days the check engine light appeared what could be going on?
it should be still under warranty so take it to a service dealer for a fault code check
if not under warranty have the fault codes read
Jan 07, 2017 | Chrysler Cars & Trucks
F&p E331T constant beep
The ActiveSmart system that manages the fridge will beep when there is fault, and the amount of beeps will indicate the fault code.
To understand the fault code, a technician would also need to know the version of activesmart, and the product ID on the grey label on the bottom right of the fridge.
Dec 02, 2016 | Refrigerators
On unlocking car constant beeping sound, this continues even when car is running, beep however changes when ignition is touched but then returns to constant beep beep beep. the central locking failed on...
Listen for the source of noise its a relay sized speaker thingy mounted in the fuse box inside the car ,locate and pull it out its easier than trying to locate the fault
Nov 29, 2013 | Suzuki Swift Cars & Trucks
Check engine warning light on 2008 chevy equinox
my equinox has a constant beeping alarm even when doors are shut and car is running
Dec 15, 2012 | 2008 Chevrolet Equinox LS
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
1994 MX6
I had a similar problem when I had my car boosted when I left my lights on. Even though I had turned my lights off the chime alerting me my lights were on would continue to chime even with the lights off AND the car turned off. I was concerned it would drain my battery again, so I took it to Mazda and they just unhooked the power to that chime. It stopped it from beeping all the time, but now I have to remember to turn the lights off.
Note... there are actually 2 chimes that I know of. I was quite surprised one day to hear the chime again - then I realized it was because my keys were in the ignition.
Jun 06, 2008 | 1994 Mazda MX-6
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
Coleman Powermate  200 Watt Compact DC/AC Power Inverter # PMP Logo
Top Coleman Electronics - Others Experts
Coss
Lawrence Oravetz
cwradio73
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
