Question about ViewSonic Pro8400 Projector
Randomly turns off - ViewSonic Pro8400 Projector
Zanussi fridge freezer
Sounds like a bad solder joint causing intermittent power issues...
Jun 19, 2016 | Zanussi Refrigerators
Map lights randomly come on
Check for a loose fuse.
Jan 12, 2014 | 2005 Ford Freestyle
Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Dec 06, 2012 | Woods Hardware & Accessories
Is there a way to put the device on shuffle mode?
  • There is a random setting rather than a shuffle mode. Same thing just a different name.
  • While in the play mode menu press "PREV/NEXT" to select the desired repeat mode ie.
  • Normal, Repeat One, Repeat All, Random, Random All, Preview.
  • You want to choose "Random" or Random All" depending on
  • Random - All music is played randomly until all songs have been heard.
  • Random All - All music will play randomly until you turn the MP3 player off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Curtis MPS2015 MP3 Player
Horn honks when turning, randomly
sounds like a electrical problem. When you turn it is completing the circuit some how, sounds like wires are touching each other and making the horn honk when turning. easiest thing is remove the fuse if possible.
Feb 06, 2010 | 1989 Volkswagen Golf
Phone turns off randomly
maybe the battery contacts is loose,try cleaning it
Jul 25, 2009 | LG KU990 Viewty
How do I turn the Random play all off.
In the main menu, go to "settings," then "audio settings," and then "play mode." Scroll to "normal" and push the center button. This should fix your problem. When you turned on Random play all, it changed this setting to shuffle, so when you return it to normal, you should be good.
Feb 01, 2009 | Creative Labs ZEN V Plus MP3 Player
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
ViewSonic Pro8400 Projector Logo
37 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
