Question about Maytag Dryers
Why are the lights on my dryer but it will not start?
When I press the power button the lights come on but when I push start it won't start.
    Problem Solver:
  • 10 Answers
There may be an issue with the sensor on the door. If the sensor isn't making contact this would still allow the lights to work but may create a disruption in the connection. I would look at both the door mounted clip and the catch on the frame and make sure they are free of any debris.
Posted on Jun 30, 2014
  • 58 Answers
SOURCE: My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
Posted on May 05, 2009
  • 9 Answers
SOURCE: Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Posted on Aug 02, 2009
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
rickead1
  • 1998 Answers
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Posted on Jul 04, 2011
  • 313 Answers
SOURCE: Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Posted on Aug 04, 2011
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
GTWN4250D1WS WON'T START. CHECKED THE POWER CORD, ALL IS WELL. WONDER IF THERE IS A FUSE OR SOMETHING ELSE TO LOOK FOR.
Troubleshooting Why Your Dryer Won Start PartSelect com Electric dryer no start does nothing
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 01, 2017 | Dryers
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Does not respond to button press and won"t turn
heatman101
Aug 31, 2011 | Kenmore Elite HE4 Electric Dryer
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Dryers Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
