Question about Danby DPAC8020 Air Conditioner
Have a Haier' Air Conditioner floor unit Model HPRB07XC7 that is suppose to dissipate the water and not need drain hose, but water is coming out of the drain what could be the problelm
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
  • 334 Answers
SOURCE: My air conditioners is a everstar model mpa-08cr,
Hey there, just follow these simple steps then you'll be on your way
To connect the continuous drain option. Remove
the water tank from the cabinet. Inside the
cabinet (water tank area) you will find a section of
hose hanging beside the water tank, which is plugged
at the end. Remove the plug
from the end of the hose and install the drain hose connector
(included with this unit) into the
end of this hose section. Route the end of the
hose (with drain connection) into the water tank,
then through the hole provided in the face of the
water tank. Attach a section of garden hose (to
suit your continuous drain option requirements)
to the drain hose connector. Place the open end
of the hose directly over the drain area in your
basement floor.
Please make sure the drain hose
section routed through water tank does not interfere
with the correct positioning of the water tank inside
the cabinet, or the will fail-safe switch mechanism will
be activated, not allowing the unit to operate.
Posted on Jun 19, 2009
SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
Posted on May 30, 2010
SOURCE: danby dpac7008 portable air conditioner
how do u turn on a silhouetto dandy floor air condition
Posted on Sep 04, 2010
  • 11 Answers
SOURCE: I just bought a Danby portable air conditioner
You use the hose only for continuous draining outside of the unit into a bucket or what have you. You don't need to attach the hose at all. I actually need the hose if you want to part with yours. coatings(at)shaw.ca
Posted on Nov 05, 2010
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
Aug 01, 2014 | Haier HWR08XC7 Air Conditioner
How to drain water from haier 8000bt portable ac
There is a drain plug on the rear of the unit, just above floor level. Before draining into a low sided pan of bowl, capable of holding 1 quart of water, turn the unit OFF & unplug it.
Another draining option is to disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | Haier Heating & Cooling
I have a commercial cool 7000BTU portable air conditioner and it seems to have shut itself down and displays a red flashing alarm light. What can I do to get it working again?
Karen, the flashing red light indicates that the water collection tank is full and needs to be emptied.
You can finds the drain plug on the rear of the unit just above floor level.
It can either be drained into a low sided bowl or pan capable of holding 1 quart of water. or you can disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Sep 06, 2011 | Haier Heating & Cooling
I dont know where the reservoir is in my air conditioner, is there a hose to hook up to drain the water becuase now it is leaking on my floor
On the Air-To Air Model, the majority of the moisture is supposed to exhausted out the exhaust hose and out the window. However, if it is extremely humid, the water collection tank will capture what is not exhausted. There is no hose, To drain it, there is a removable drain plug on the back of the unit, down near the floor level. You can either drain it in a low sided pan, that is capable of holding at least 1 quart of water. Or you can disconnect the unit and roll it to a floor drain (if you have one) or out doors to drain the water.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | DeLonghi Air-To-Air Portable Air...
I own 2 Haier air conditioners. Same model number, purchased at the same time. Plugged them in yesterday and one is collecting water in the bottom and shuts off. The only way to get it to come back on is...
Condensation occurs when warm, humid air is pulled across a cold fins of an air conditioner and blown out the front as cool, dry air.
What is happening with your air conditioner sounds to be normal operation - here's why:
The condensate usually drips onto the ground from traditional window air conditioner units or through a pipe to the ground from remote air handlers of split systems. Since yours has no place to drain away into soil or waste pipe, it is collected in a compartment that must be emptied, just like a dehumidifier. When the compartment is full, the unit shuts off - otherwise the compartment would overflow on the the flooring or carpet. This could be a very expensive repair if hardwood floors were damaged or carpeting were to become moldy. Even more so if the the space under yours were finished - like an apartment building or if you used this on the second floor of your home - and damage to the ceiling below were damaged.
You could operate the device if it were connected by a hose to a drain at or below the bottom of the connection point (a floor drain, shower drain, etc.) or if the unit were placed on a counter top and allowed to drain into a sink or other drain / waste pipe below the the hose connection point. The hose must not get higher than the connection point at the drain plug on the air conditioner to work properly.
I hope this helps and good luck.
Apr 25, 2011 | Haier HPR10XC6 Portable Air Conditioner
I have a window unit (ESA 3109-L) that I purchased this summer. I came home from a long weekend away to find water all over the window sill, drywall, and floor. It's coming from the air conditioner. Any...
First.The unit needs to be tilted back more so the water drains out of it to the lower back of the unit.
Next,make sure the drain hose or hole is not clogged up.
Last,if this never happend before be sure you didnt have any bad wind and rain while you were gone,somtimes a hard driving storm with wind drivin rain can find its way in around the a/c .
Aug 24, 2010 | Haier Heating & Cooling
Water leaks out all over the floor from the window air conditioner
you need to make sure of two things.
1) the AC is 'tilted backwards' just a little bit - to allow the water (condensate water from the evap coil) to drip from the bottom of the AC - out the 'condensate drain hole' - sometimes into a drain hose (usually rubber) or just through the hole to somewhere outside where it doesn't hurt anything.
2) make sure the - condensate drain hole, and drain hose - (if one is used) is clear and not clogged up - to allow the condensate water to drain.
hope this helps
Jun 26, 2010 | Haier hwr10xc6 Air Conditioner
Shuts off after a while i noticed water was coming out with the air do i have to drain this unit
The drain might be backing up. You probably do need to drain the condensate water. The unit should have a small hose at the bottom in the back where the water will gravity drain out.
Jun 19, 2009 | Haier HPAC99ER Air Conditioner
Haier Air Conditioner Model #HPRB07XC7
call 1 800313 8495 haier part dept they will get you one i had to get one myself
Jun 26, 2008 | Haier HPAC99ER Air Conditioner
Danby DPAC8020 Air Conditioner Logo
15 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
