Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to remove deck - Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Sergeant:
  • Craftsman Expert
  • 374 Answers
Remove 2 pins from top back of deck and push the bracket pins out of the holes. remove 2 pins from deck front rods and pull rod end from holes in deck brackets. remove deck engage cable.
Posted on Oct 16, 2014
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 | Toro Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Reebok tr5 treadmill deck replacement instructions
take the side rails off,unbolt or unscrew the deck and replace deck.
Nov 01, 2013 | Reebok Exercise & Fitness
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
I need to know how to take deck loose to replace the belt.
To remove the deck from a riding mower you will need to lower the deck fully first. Then laying on the ground look above the deck and see at what points the deck is connected to the rest of the mower. Also at this point, remove the belt from the engine pulley. You should see some pins that can be removed to unhook the deck. For example on a Craftsman 42" there are two on the front of the deck, two above the deck connected to the lowering mechanism and one to guide the back up and down and one that connects the cable/linkage for engaging the deck. Then raise the lowering mechanism up out of the way and the deck should just slide out. With the deck removed take note of the routing, but usually there is a belt routing sticker on the deck.
Under the seat you will find the make and model number, record these and take to your local lawn mower repair parts store and they should have the appropriate replacement belt.
If this was really helpful, please rate.
Jul 10, 2011 | Garden
How to remove shaft assembly from mandrel housing of a husqvarna yth2348
It's much easier to do on the tractor.
1. Leave deck installed.
2. Jack tractor up and lower deck.
3. Run a heavy wire through the mandrel pulley's tie down hole.
4. Raise deck and tie wire around the deck.
5. Lower deck and remove top nut.
6. Raise deck and remove shaft.
You can modify this procedure to loose the nut if you don't have a jack and remove it once the deck is off. Retorque nut to 35 ft. lbs during install.
Apr 25, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do i take out the mandrile
remove the blade, remove the deck from the tractor, remove pulley covers, remove the deck belt, remove the bolts holding mandrel to deck, remove the mandrel. reinstall in reverse order.
Jun 23, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cd stuckinside the deck
question to u is the deck still on is the deck powerd up............if so you will have to replace the deck you can remove the cd with a little work once the deck is removed.........good luck
Nov 30, 2009 | 2005 Acura TL
How do I remove the cutting deck on a Craftsman LT1000?
pull the pins from the rods attached to the front of the deck. then let the deck all the way down. remove the pins in the deck lift arms and remove the pin in the top of the tension pully and lift the end of the cable off the pully remove the clip holding the blade ingadgment cable in place . pull the pin in the arm at the back of the deck disconnect all of the rods you pulled the pins out of and slide the deck out. put it back in reversing the above prossess.
Jun 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you remove the mower deck from a craftsman riding lawn mower
Most of these have a cable to pull deck into gear, which has a r clip to remove ,than two rods that go from font of deck towards front axle- remove 2 R clips to drop them, and 2 more at the back of deck, un hook belt around engine pulley, than slide deck out. See how this goes. Or you my have dune it by now.
Dec 15, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
132 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
