Question about Hoshizaki Commercial Freezer KM-500MAH
Very slow to make cubes - Hoshizaki Commercial Freezer KM-500MAH
Ice maker leaking out the bottom and refreezing ice cubes to a big glob
are the cubes coming out of the unit? Sounds like the heating element is not activating, to release the cubes prior to refilling. Check electrical connections at the rear of the unit against the freezer wall that they are together. If ok then defrosting element may be defective, Replace unit.
Aug 27, 2013 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
One cube has a face equivalent to the total area of another cube. find the ratio of their volumes?
Let the sides of the cubes be a and b,
the length of the diagonal of the cube whose side is b is given as square root(3)*b
according to the given question,
a=square root(3)*b
the volume of the cube with side a is given as
v1=a^3=(square root(3)*b)^3
and the volume of the cube with side b is
v2=b^3
then their ratio of volumes is given as
v1/v2=3*square root(3)*b^3/b^3=3*square root(3)
i.e v1:v2=3*square root(3):1
Next qwasthun pwease :D
Jan 06, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Ice cube tray will not release ice cubes
Simply buy a replacement tray. The flexability of the old tray is gone and so no flex means cubes stay put. Aggrevating. A new flex tray is around 20 bucks and very easy to replace. 59688-1 is the part number.bca6e53.jpg
May 22, 2009 | Freezers
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Commercial Freezer KM-500MAH Logo
65 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
