Question about iLive ITP582B Soundbar iPhone Dock
How do I hook sound bar up to tv for volume - iLive ITP582B Soundbar iPhone Dock
I have hooked the ilive sound bar up to.the cable box but the volume won't stay on
the hdmi cable is given priority it has the box's sound routing
hook the bar to the tv output
you might have to activate that in the tv menu.
Jan 05, 2015 | Televison & Video
Tcl tv sound
New 48" TCL tv. Hooked into cable box via hdmi cable from hdmi 2 per instructions. Problem is no sound. Screen looks great volume bar shows volume etc. Any ideas before I take it back to SAMs.
Jan 05, 2014 | Televison & Video
My TV has terrible sound at volumes where we can actually hear the TV. It gets warbled like the speakers are bad.
The TIVO system is not a problem. I have it and it works fine. Make sure all the cords are plugged and screwed in tight.
Nov 06, 2013 | Televison & Video
Volume on hanspree tv
this is a big problem which you can't solve by yourself. some times software problem , the tv want to be upgraded. this operation is very delicate and must be performed by a professional technician . second solution is to remove the digital board, here again , that board is expensive and i know you can;t take risk to do by yourself.
Solution. if you are under warranty call the company which will fix for free or bring it in repair shop.
Mar 12, 2012 | Hannspree HG281DPB 28 in. LCD TV
I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
Feb 26, 2012 | Televison & Video
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
No sound
When my sound output set to off and I use the remote to change volume; it tells me speakers off.
Try a different output method: hook up headphones, other speaker type... these answers should help you find a solution.
Feb 27, 2010 | Televison & Video
iLive ITP582B Soundbar iPhone Dock Logo
23 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
