Question about Haier Heating & Cooling
Have a Haier' Air Conditioners Model #HPRB07XC7 doesn't dissipate the water?
SOURCE: Haier Air Conditioner Model #HPRB07XC7
call 1 800313 8495 haier part dept they will get you one i had to get one myself
Posted on Jul 29, 2008
  • 334 Answers
SOURCE: My air conditioners is a everstar model mpa-08cr,
Hey there, just follow these simple steps then you'll be on your way
To connect the continuous drain option. Remove
the water tank from the cabinet. Inside the
cabinet (water tank area) you will find a section of
hose hanging beside the water tank, which is plugged
at the end. Remove the plug
from the end of the hose and install the drain hose connector
(included with this unit) into the
end of this hose section. Route the end of the
hose (with drain connection) into the water tank,
then through the hole provided in the face of the
water tank. Attach a section of garden hose (to
suit your continuous drain option requirements)
to the drain hose connector. Place the open end
of the hose directly over the drain area in your
basement floor.
Please make sure the drain hose
section routed through water tank does not interfere
with the correct positioning of the water tank inside
the cabinet, or the will fail-safe switch mechanism will
be activated, not allowing the unit to operate.
Posted on Jun 19, 2009
  • 3289 Answers
SOURCE: I own 2 Haier air conditioners. Same model number,
Condensation occurs when warm, humid air is pulled across a cold fins of an air conditioner and blown out the front as cool, dry air.
What is happening with your air conditioner sounds to be normal operation - here's why:
The condensate usually drips onto the ground from traditional window air conditioner units or through a pipe to the ground from remote air handlers of split systems. Since yours has no place to drain away into soil or waste pipe, it is collected in a compartment that must be emptied, just like a dehumidifier. When the compartment is full, the unit shuts off - otherwise the compartment would overflow on the the flooring or carpet. This could be a very expensive repair if hardwood floors were damaged or carpeting were to become moldy. Even more so if the the space under yours were finished - like an apartment building or if you used this on the second floor of your home - and damage to the ceiling below were damaged.
You could operate the device if it were connected by a hose to a drain at or below the bottom of the connection point (a floor drain, shower drain, etc.) or if the unit were placed on a counter top and allowed to drain into a sink or other drain / waste pipe below the the hose connection point. The hose must not get higher than the connection point at the drain plug on the air conditioner to work properly.
I hope this helps and good luck.
Posted on Apr 25, 2011
SOURCE: The alarm light on my Haier HPRB07XC7 Portable Air
Empty the drain tube, which is located in the back of the unit towards the floor and you should be good to go.
Posted on Jul 07, 2011
SOURCE: weres the fuse in haier air conditioners
Car A/C? Could be a thermal shut down for low freon. Once it sits a while will it come back on? If so, it's not a fuse.
Posted on May 01, 2012
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
Aug 01, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Haier Wall Air Conditioner. It's on cool
Filter may be clogged. I have one and it has a filter which I clean regularly.
Sep 11, 2012 | Heating & Cooling
HAIER ONly blows air on one side
Possible that the vent or the vane is blocked which can also be due to a jammed motor in the auto oscillation vent.
Remove the panle and check the free movement which will confirm this case. Sometimes it could be dirt that is logged in that prevents free movement.
Jul 03, 2012 | Haier HPRB07XC7 Portable Air Conditioner
Window / through wall unit made by haier, i can't find a model number. but it's making an awful racket like a blade or something hitting something. also slightly blows out a light fine mist of...
Where the unit drains is clogged it sounds like so your fan blade is hitting the water and scooping some of that water indoor. look where the condensate drains and clean that and it should be fine
Aug 14, 2011 | Haier ESA3125 Wall/Window Air Conditioner
It light a red light "ALARM", and it doesn't start. I need to know how can I reset it.
It would really help to know which model (model number) Haier AC Unit you have.
Please advise ... Thanks
Jul 14, 2011 | Haier Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
HAIER Model # HWR06XC3 not working :(
If this does not work, call an air-conditioning technician--the refrigerant ... 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. ... may be blocking the water's flow, or leaking, or the pump may not be working. ...
Jul 09, 2010 | Haier Heating & Cooling
Jun 26, 2008 | Haier HPAC99ER Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
