Question about Lexmark C920 Led Printer
Reset counter C920 - Lexmark C920 Led Printer
Lost connection to computer
Unplug webcam from computer. Shut down computer. Connect webcam to computer. Re-boot computer. You might do a web search for: Logitech HD Pro Webcam C920 driver, if you don't have a CD that came with the webcam.
Mar 14, 2016 | Logitech Hd Pro Webcam C920 Widescreen...
HD Pro Webcam C920 V-U0028 860-000334 LWS 2.40 LWS
If you're looking for a Windows Driver for this WebCam, try this location:
http://www.logitech.com/en-us/support/5798#section=downloads
From there, you select the appropriate operating system from a dropdown menu, then you can download the correct software for your hardware.
Good Luck!
Oct 16, 2013 | Computers & Internet
How to reset Fuser Replacement 80 on C920 Lexmark - new fuser hasn't reset the warning
Go to Configuration by pressing the Check button the right arrow button while powering up the printer. Then choose reset fuser count. Hope this helps.
Jul 13, 2010 | Lexmark C920 Led Printer
I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
Feb 22, 2010 | Lexmark C920 Led Printer
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
What is a 991.00 error
Assuming you are working on a Lexmark C920. The 991.00 service paper option relates to paper being jammed behind one of the paper drawers. Remove the paper drawers and check the connecters and also the housing for the tray its self.
Clear any errant paper and replace the drawers and all should be well.
Sep 23, 2009 | Lexmark C920 Led Printer
How to update s/n on Lexmark C920
go to lexmark site and download printer files
Aug 10, 2009 | Lexmark C920 Led Printer
LG Vu C920 automatically switches off while charging
i know this sucks but you may need a new battary.
Apr 13, 2009 | LG Vu CU920 Cellular Phone
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
