Power board mpo2008
A mutch is cost
My car foes not start towed it to a garage they said it needs a software upgraded ,its a BMW 320d,2007 make .much can it cost
I will depend on what is the cost by the hour of your local bmw dealer and how mutch time it will take them.
usualy it's about 180$\ hour and should take about 3hours .
Nov 05, 2015 | BMW Cars & Trucks
09 Jeep Grand Cherokee ;Won't Star, No Crank, light are bright, radio works, battery fully charge, terminal clean,alarm working
You need a new start reele you can find this part at your dealer and it dont cost mutch, repearing manual can be found online..
Jan 12, 2015 | Jeep Cars & Trucks
I have an issue with getting power to my laptop what can i do i think something may have fried internally
so what happened did you try a different power supply does it smell burnt is so you do need a new board there about 100.00 new or you can get one like it from ebay for parts or buy one like there not mutch i just checked there alot available.........
Apr 12, 2011 | Compaq Presario 700 470024-192 Notebook
1mtr cat6 patch cable how mutch it cost please ? i need 1000 pc
It should cost around US$ 4.00 per cat6 patch cable. For 1000 pc. you must negotiate with the amount to get a better price quote.
Apr 05, 2011 | Systemax CAT6 Patch Cable
No power getting to the comp and its not the cord. I hit power button and nothing. Is there a power control circet in the upper part of the tower that could have gone bad. I did not find any bad fuses or...
It is all explained in my guide, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! It could be the power supply or a short circuit, but may also be a loose connection or dead mainboard. However you must diagnose the fault before you purchase replacement components, other wise it could cost you lots.
Thanks
damnor01
Nov 15, 2010 | Compaq Presario S5140WM (DM198B#ABA) PC...
My packard bell has stoped charging
If your laptop has stopped charging and you've already replaced the AC adaptor, then most likely it's either the battery itself or the power port on your laptop. If the battery was fine up to that point then it's probably not the battery. To replace the power port can sometimes involve soldering the new port onto the motherboard of your laptop so it's usually best left to a professional. The port you can usually find on ebay. I've replaced a few that is just a small power board that plugs into the mainboard but other have to be soldered. It's not really hard to do, but it involves dismantling the whole laptop to gain access to the motherboard and sometimes requires soldering. Sometimes its very obvious and you can tell by trying to move the metal pin in the center of the plug on your laptop where it plugs in. If the center prong moves then it has become detached and must be replaced. If not it could also be a connection problem due to corossion. Without pulling it apart and looking at it, it can be hard to tell. Deptending on the extent of the work, it can cost from 50.00 - 200.00. I hope this helps.
Apr 17, 2009 | Packard Bell Easy One Silver 2120 Notebook
R REG MEGAN CAM BELTSTO BE CHANGED HOW MUTCH COST
depends where you go. between 90 and 130 i expect.
Mar 26, 2009 | Renault 181 Cars & Trucks
Kenmore elite washer wont spin during cycle and makes a buzzing noise.
washer turns very slow came up with alarm #20 .
can you tell me what and how mutch it will cost.
thank you
Aug 24, 2008 | Kenmore Washing Machines
My tv acts as though it is not plugged in
not mutch you can do,savety circuit has tripped the set.
needs a repair person.
horst in wollongong
Mar 26, 2008 | Panasonic CT-32SL13 32" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
