Question about Kitchen Ranges
I have an Jenn Air electric oven, wall mounted. The touch pad is not responding and cannot set the clock or temperature for baking/broiling or other applications. Panel LCD is on.
  • 2 more comments
  • prakash_sule Jun 23, 2009
    I have tried this once, but shall try once again and come back to you.
    I do not see a solution to my problem "the touch pad is not responding". You have provided the operating instructions, which are of no use to me if the touch pad is not responding. Thanks for your efforts.
    I had unplugged the oven and restarted it after one hour, but this does not solve the problem.
    The second respondent has provided the operating instructions which do not help me, since the touch pad is not responding.
    The problem has not been solved.
  • prakash_sule Jun 24, 2009
    I have done this already, since the oven is under Warranty.
  • 10,515 Answers
Touch Pad - It's a part of Control Panel
More likely, it is due to Defective Bad Control Panel. It has nothing to do with timers and cannot be cured by unplugging and plugging.
If under warranty, RETURN IT. If not, Look at the part number and order at
http://www.easyapplianceparts.com/Jenn-Air-Oven-Parts.htm
I hope you would be able to get the part as the company have stopped manufacturing most of the spare parts for ovens.
Hope i have helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
  • 241 Answers
OVEN COOKING The control panel is designed for ease in programming. The display window on the control shows time of day, timer and oven functions. Control panel shown includes model specific features. (Styling may vary depending on model.) Using the Touchpads • Press the desired pad. • Press the number pads to enter time or temperature. • Press the Autoset pad to enter temperature. • A beep will sound when any pad is touched. • A double beep will sound if a programming error occurs. A CANCEL Cancels all operations except Timer and Clock. B Clean Use to set self-clean cycle. C Bake Use for baking and roasting. D Number Pads Use to set time and temperature. E Oven Light Use to turn the oven light on or off. F Keep Warm Use to keep cooked food warm in oven. G Toast Use for toasting, top and bottom browning. H Broil Use for broiling and top browning. I Timer Sets the timer. J Clock Sets the Clock. K Cook & Hold Bakes for a preset time, then holds food warm for one hour. L Delay Programs the oven to start baking at a later time. M Favorite Use to set and save a specific Cook & Hold procedure. N Autoset Use to quickly set temperatures. Note: Four seconds after entering the number, the time or temperature will automatically be entered. If more than 30 seconds elapse between touching a function pad and the number pads, the function will be canceled and the display will return to the previous display. Clock The clock can be set to display time in a 12-hour or 24-hour format. The clock is set at the factory for the 12-hour format. To change the clock to 24-hour format: 1. Press and hold the CANCEL and Favorite pads for three seconds. • 12 Hr flashes in the display. 2. Press the Autoset pad to select 24 Hr; press again to select 12 Hr. 3. Set the time of day following the directions in the To Set the Clock section. Timer The timer can be set from one minute (00:01) up to 99 hours and 59 minutes (99:59). The timer can be used independently of any other oven activity. It can also be set while another oven function is operating. The Timer does not control the oven. It only controls a beeper. To set the Timer: 1. Press the Timer pad. • 00:00 and TIMER flash in the display. 2. Press the appropriate number pads until the correct time appears in the display. • The colon and TIMER will continue to flash. 3. Press Timer pad again or wait four seconds. • The colon stops flashing and the time begins counting down. • The last minute of the timer countdown will be displayed in seconds. 4. At the end of the set time, one long beep will sound and “End” will be displayed. 5. Press the Timer pad to clear the display. To cancel the Timer: 1. Press and hold the Timer pad for three seconds. OR 2. Press the Timer pad and press ‘0’ using the number pads. Broiling To set Broil: 1. Press the Broil pad. • BROIL and 000 flash in the display. • SET flashes. 2. Press the Autoset pad once to set HI broil or twice to set LO broil. • HI or LO will be displayed. Select HI (550° F) broil for normal broiling. Select LO (450° F) broil for low-temperature broiling of longer cooking foods such as poultry. 3. After four seconds, the oven will start. • BROIL will remain lit. • HI or LO will remain lit. 4. Preheating is not necessary when broiling. 5. Place food in the oven. Close the oven door. 6. Turn meat once about halfway through cooking. 7. When food is cooked, press the CANCEL pad. Remove food and broiler pan from the oven. • The time of day will reappear in the display Clock, indicator words, and/or • Oven may be set for a Cook & Hold or Delay function. lights operate but oven does • The Control Lock may have been set. not heat. Oven light and/or clock • The light bulb is loose or defective. does not function. • The oven light does not work during self-cleaning process. • Oven may be in Sabbath Mode
  • 749 Answers
Hi, it seems like the touch pad panel is malfunctioning, try to unplug the oven for 30mins and try again, if that does not work you will have to replace the touch panel.
Preheat goes to 100 degrees and stays there. All push buttons to 27 in Jenn-air oven work and after 45 minutes unit heats up.Now not heating up at all.
whenever you set an oven it always starts at 100,if that's an electric oven most likely the bake element is bad and the broil element is just working and heating up the oven,when you set the oven to bake both the broil and bake elements get hot.if it's gas most likely a bad ignitor,send the model number if you write back,also if that's an electric oven make sure you flip the breaker so there's no power going to the oven before you try to remove the element,i see people try to remove the element with the power still on and when they pull out the element the wires touch the metal and bang they short out the clock assy.kill the power,remove the two screws that hold the element in place or if this isn't a wall oven slide out the oven,unplug it,remove the back wall and with a meter read out the element,remove at least one of the wires first and then check it,very simple set your meter to 20k,ohms touch the leads to the element where the wires connect to it,if you see a 1 the element is bad or open,if you see anything else but 1 the element is good or closed,hope this helps you out
May 26, 2018 | Jenn-Air Ovens
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Oven touch pad not working properly.
Hi. this will only get worse. i would replace this defective touch pad asap if possible.
Jun 23, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
211 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
