Question about Cell Phones
Blind Screen I Dropped it, in a leather case, and the screen has turned into vertical stripes based off of what's supposed to be there. I've been able to interact with it, and it responds correctly, but it is "blind", as it were. i have been told the color, screen setting can reboot it where as a hard reboot couldn't. Yes, I tried the hard reset, same result. I want to know if there is another way. It would take me a long time to find the reset, if it exists, because I'm using the tablet blind. HELP ME!!!Is there a reset, such as described, or not?
  • 507 Answers
Ouch it sounds more like the LCD inside the tablet needs replacement as no sort of resetting will help
Posted on May 06, 2017
  • 216 Answers
SOURCE: Nikon Coolpix 5700 with stripes
It's a free Nikon recall for a defective CCD sensor. Go here and find the Nikon link:
Posted on Jul 10, 2006
  • 5 Answers
SOURCE: Samsung A707 SYNC. No main screen display
the flex of the phone is bad so change the flex
Posted on Dec 22, 2008
  • 135 Answers
SOURCE: Color distortion/blank screen on 50% of monitor
Full instructions from DELL at:
Please rate this response thanks.
Posted on Feb 22, 2009
  • 7 Answers
SOURCE: vertical white striped screen
If a lot of pressure is added to the screen this can cause it to fracture internally. Sounds to me like you need a trip to an Apple repair center if you've already tried rebooting it.
Posted on Apr 13, 2009
SOURCE: Magenta vertical stripe sets plus grid dots problem
Staples office supply store said it was the monitor and, after buying and installing a new $200 monitor, I discovered it wasn't the monitor. I brought my hard drive to a reputable computer repair place, who charged me $50 total to install a new video card. He also supped up my hard drive with an additional 512K ram for $20 and now things are so much better. You were right! It was the video card.
Posted on May 15, 2009
Vertical rainbow stripes on my GB color
I would say that the screen is causing the lines in a gameboy colour the lines are not the same like it would be in an orginal gameboy the one with the four batteries. Lines in gameboy color are the screen issues then the whole screen would have to be replaced on the GBC then.
May 18, 2013 | Nintendo Game Boy Color Console
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
Display issues
no photo posted, of bad screen, why? why make help blind?
the display LCD is bad.
or is the 2008 , solderballs Nvidia chip failure.
if the screen fails in BIOS (press f10 or ESC to enter setup
an fails under boot CD linux or any kind the screen is bad
test with big battery out, always. run on AC power only to test.
do the funny LINES change if you gently twist screen case?
i see reviews on this LT back to 2009
the vista review page on its support pages is stamped 2008
oops !
the BIOS screens are here. hit ESC then F10
this is called hp setup, its BIOS.
if these screens look bad, bingo for bad screen LCD or the GPU.
Jan 01, 2018 | HP Pavilion dv7-1245dx Notebook
Turning it on the picture is fine and clear but after a short time the screen switches from picture into vertical stripes
Hi Karl,
First of all, thank you for posting your question here at Fixya.
The symptoms you've described is an indication of fault on the LCD controller board(T-con board) inside the TV. This board processes the images and will feed to the LCD panel to generate picture. The chips and other parts on this board gone bad that's why the screen turns to vertical stripes after a short period of time because of an overload. It is located at the bottom center inside the set and covered with metal shielding.
I've saw this board at I would advice you to check the actual part no. of your T-con board that is printed on the board itself because there's some instances that the manufacturer used different version of this board(depend on the LCD panel) with same model number.
Also, don't forget to check if your unit is under warranty period (1 year), if so avail it because the manufacturer will fix it for free. Opening the rear cover will void the warranty.
Hope I helped you.
Again, thank you. Good luck and take care!
Dec 17, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Screen only showing vertical lines after being dropped
The damage could be either in the LCD screen or the connection cable. Open the screen assembly and check the connection cable first.
In case it doesn't work you can find replacement LCD screens here.
Jul 02, 2008 | Toshiba Satellite M55-S135 Notebook
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
