Question about Noritz 7.1 Gpm Natural Ng Gas Tankless Hot Water Heater
Water is turning cold after a few minutes running time?
Model #N-0631S
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: have hot water for a
The problem may be the flame sensor or the control.....
Check that the flame sensor is clean and also that there is a good ground from the burner to the control....make sure that the wiring to the unit is correct polarity, and then the ground is hooked properly also...
Is it flashing a code and if so, check what the code means....
heatman101
Posted on Dec 21, 2010
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Is it safe to replace the blown fuse which serves only my small hot water system?
fuses wear out over time even if you dont have short to cause it to blow. yes you can replace the fuse,just be sure to off the power to the box before you do.
Jan 04, 2013 | Water Heaters
How do I manually change the temperature on Noritz N-0631S tankless water heater if I don't have the optional remote controler?
There are temperature jumper clips located on the inside left wall of the heater. They will be in a small plastic baggie. The procedure is as follows:
1. disconnect power
2. install the jumper connector in the plastic slot located between the remote control screws on the circuit board (right hand side of the heater)
3. reconnect power
Mar 06, 2011 | Noritz Residential Heaters Tankless Water...
There seems to be a flow problem. The pressure starts out fine and ends up a trickle but only on the hot side. I have used the T & P valve to try and back flush the unit , to no avail
In order to clean the unit you need to connect a small sump pump to the cold inlet, and run a hose from the hot side into the same bucket. Pour about a gallon a white distilled vinegar in the bucket, and turn the pump on. Let the solution run through the unit for about 15 minutes, then reverse the hose connections and run the pump for another 15 minutes. Reconnect the water supply and outlet. Turn the water on in the bathtub first on the hot side and let ir run for a few minutes before turning the power back on to the heater. While the water is still running turn the power back on and reset the thermostat. If you get a lot of debris in the bucket, you may need to consider installing a water-softener to prevent scaling.
Sep 17, 2010 | Bosch & Tankless LP Hot Water Heater
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Cold water coming out of hot water faucet. Was told it was crossover. What's going on?
did you install it or someone else?The first thing I would is check under the sink and look at the pipes coming out of the wall.Hot is suspose to on the left and cold on the right.You tell by turning the water on {let it run for a few minutes}and touch the pipes.
Mar 14, 2009 | Water Heaters
Noritz 7.1 Gpm Natural Ng Gas Tankless Hot Water Heater Logo
51 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
