Question about Cameras
Ems 55 r advanced - Cameras
Why if my antena is hooked to my dvd player is it not getting channels but my tv is if dvd player is turned off
The reason probably is because all broadcast TV is digital, and the em-55 tuner is set for analog channels. It cannot receive today's broadcasts "thru the air" because channel 2 for example is not broadcast, rather channel 2.1, 2.2, etc.
You can use the signal with a new TV, but when you turn ON the em-55, it inserts channel 3.
Most all TV here has what I call sidebands, and some have as many as 11, so the tv can be set for 3.1, or 3.2 or 3.3.
Even if you have a digital-to-analog device, the em-55 will not receive any .1, .2, .3, .4 and so on. I verified this recently reconnecting my old antenna to the converter then to several VCR's and DVD players.
Turn off the em-55, and the dot channels pass through the RF connectors..
Some DISH, cable direct TV receivers convert the signal to ch 3.
Sep 25, 2014 | Panasonic DMR-E55 DVD Recorder
Looking for a replacement LCD screen for a Gameboy Advance, any ideas?
The best place i can think of is a second hand Gameboy thats in poor shape and cheap enough and swap 'em
Oct 09, 2009 | Nintendo Game Boy Advance SP GBA Black...
My meter won't work even with new batteries?
I have Nikon EM myself and I have an issue with meter myself. First, the camera won't start metering unless your film counter is at 1 position. So, you have to advance couple of frames in order to have the camera start metering. Second, my unit will show metering information when I press the shutter half way IF I have not advanced the film to the next frame. As soon as I advance the film and ready to take the pic, the meter needle drops and won't show any information. This is caused by the aperture arm of the camera dropping a little bit from it's initial position as soon as you advance the frame. Funny thing is that the camera will continue to meter and make correct exposure, just without the information displayed.
Aug 06, 2009 | Nikon EM 35mm SLR Camera
Nikon EM film winding lever is stuck. Can I repair this myself? Purchased at a yard sale with loads of lens and worked great for about 7 rolls of film. Shot part of a roll and lever refused to advance...
Bad news. I have an EM on the junk pile for a similar reason. In my case, the lever stuck and when I tried to advance the film, the plastic on the top of the camera body fractured and the whole mechanism separated. The current E-bay price on an EM body is under $30. Since the EM was made out of plastic, it is not repairable. If you have several lenses, it will be worth the low cost.
I have had Nikons of various models for over 50 years and in my opinion, until they fail such as your has, the EM is probably the most comfortable non-professional 35mm camera to hold and use that Nikon ever made.
Nov 22, 2008 | Nikon EM 35mm SLR Camera
Shutter fires when film advance lever is used.
The problem you describe is common with the EM. I have one myself sitting on the junk pile for the same reason. The body is made of plastic and the plastic around the advance lever is a week point. Your body, unfortunately is not repairable. But there is good news. Because of the low cost of a replacement EM on E-bay (under $30), you should consider keeping your lenses and buying a new body (the standard 50mm f1.8 EM is superbly sharp for a low end lens). Since the EM lenses are interchangeable with later models, you could consider a later model used body. Many are selling for fire sale prices.
Sep 23, 2008 | Nikon EM 35mm SLR Camera
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
Cameras Logo
69 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
