Question about LG CF360 Cell Phone
My phone doesn't make a call, no sound, then it says to "retry timer expired"
Screeb lights up as if call going thru, but no sound, then it tells me to retry. i can't call my phone either.
Radio plays, sounds bad, display doesn't work
Your speakers are just fine!! Original radios and some newr radios do have expiration dates. You have to look at the year of the car and if the radio is original . The display not showing is a great sign to know thats its gonna go out sooner or later. It's cheaper to get another than to figure how how much it cost to fix.
May 10, 2012 | 1986 Ford F150 SuperCab
Re Gilmour water timer 9200 - if timer not working (water is going thru but time does not change) is there a battery inside to change? How get at?
There is no battery, this timer is water driven. I looked on an Amazon site and several users were complaining that it doesn't shut off once it starts.
Check the inlet for debris in the filter or inlet opening.
I have no other ideas.
Gary
Sep 09, 2011 | Do-It Gilmour Group 9200DIB Do it Water...
Used the dryer at night. Put a new load in at 8am Set it for 40 min. Lights were on put it was not spinning. Retried 4 or 5 times but it will not spin. I bought it 2009 I have not used it much.
Usually when the drum doesn't spin it is 1. the motor. 2. the belt 3. timer.
The motor is a little over a $100 the belt $25-30 and the timer around $100. And it would be somewhere in the $150-200 labor fee if you aren't going to do it yourself.
Jun 04, 2011 | Amana Dryers
No sounds
if your computer have no sound than first check speaker. if you doesn't find problem maybe you have driver problem. so go to desktop right click on my computer than select manage and than click on device manager if you find sound, video and game controller in yellow high light so your driver was expire so just update your driver. thats it!
May 06, 2011 | Computers & Internet
I have an amana air command 90 furnace. the burner won't light.
This unit goes in steps, 1-- thru--4 Step 1, vent fan blower motor runs & prove thru the air tube, which closes a switch and tells the circuit board to go to step---2 Step 2 lights the glow plug and goes to step 3 automatically, Step 3, opens the gas valve and send in gas thru the long venturi tubes which lights from the glow plug and on the last tube, theres a rod that sticks into the flame, if no flame or not working properly, it will shut down the starting sequences and retry for 4-times and automaticaly lockout till unplug and start over. (whever step it stops at, then thats where your problem is!
Sep 06, 2008 | Amana Heating & Cooling
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
LG CF360 Cell Phone Logo
52 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
