Question about Dehumidifiers
How to remove front panel on Kenmore dehumidifier
Just purchases a kenmore dehumidifier and appears to work, but the bucket is completely dry.
ck your settings on control panel , lots of times they set the set point high at factory so it wont turn its self on to remove water . also ck your rooms available humidity level sometimes there's not enough water in air for one to remove much
Feb 13, 2014 | Kenmore Dehumidifiers
Model # 5641 dehumifier- how do you remove the cover to oil the fan?
Pull the humidistat dial off. Remove two screws on the bottom of the front panel. Pull the panel off from the bottom. There are two tabs on the top that will come out when the panel is rotated approximately 45 degrees. There are two oil ports on the top of the motor. Reverse the process to rerassemble the dehumidifier.
Sep 24, 2011 | Kenmore 54501 Dehumidifier
The Bucket Sensor light is always beeping and the front panel says 01. The machine refuses to work
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 18, 2011 | Kenmore 54501 Dehumidifier
Ice builds up on the coil and will not defrost until unit is cut off . I can not remove front panel, how is this done.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jun 14, 2011 | Kenmore 54501 Dehumidifier
Ice forming on top of unit between the front panel and unit.
The filter is clogged on the unit. Unplug the unit and let it defrost. You may want to put some towels or old newspaper under it to absorb any possible drippings. Once the unit has completely thawed, remove the filter and clean it. If it's an aluminum mesh filter, you can back flush it and then wash it with soap and water. Rinse thoroughly and let dry completely or use a blow drier to speed up the drying process.
Hope this solves your problem.
Mar 08, 2011 | Kenmore 54501 Dehumidifier
How do you get the front grill off?
Remove water collection bucket. Remove two screws now visible (previously covered by top edge of bucket). Front panel now has to be flexed a bit on the side to release it from the metal side panels, near the lower portion of the front panel, then panel swings up and un-hooks from top.
Mar 01, 2011 | LG LHD45EL Dehumidifier
I have a Kenmore dehumidifier model 580 -54501 it will not stay on. goes on but flashes 01 on the screen.
For sure this is an error and could be a fault in the heater panel or the motor drive.
Must remove out and check if the fault goes off on disconnection of one of the above.
Sep 28, 2010 | Kenmore 54501 Dehumidifier
I have a old Kenmore 40 dehumidifier and the pan light is on. So, I checked the pan and there is only small amount of water. I dumped it and put the pan back and the light is still on. The light goes off...
That is normal. Check the little lever inside the bucket to see if it is moving freely.
There is a little red button that you can see inside the left front side (looking at the unit) when you remove the bucket. Press the button to see if it is sticking.
May 14, 2009 | Kenmore 54501 Dehumidifier
Help for old kenmore dehumidifier
Hello Sandy,
On mine, the filter is in the front. Behind the grill. To remove it, you have to remove the bucket first. Then you can see two tabs sticking down that say "Filter Front". You can reach your fingers up & behind it, grab the lip, and pull straight down. For me it requires more force than expected. With the filter out, put the bucket back in and turn it on. Make sure that there is air blowing out the back to verify that the fan still works. I hope this helps.
InSub.
Jul 31, 2008 | Dehumidifiers
Dehumidifiers Logo
43 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
