Question about Hayward SAND FILTER, PRO SERIES
What is the sand capacty for sp 711 model hayward filter
    Top Expert:
  • Hayward Master
  • 5,743 Answers
On side should show sand cap
Posted on Mar 05, 2016
4 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: I need to change the sand in a hayward model 711
While there is a model 711 Hayward Valve assembly, the actual filter is a different model number. You might be able to find your model here...
http://www.haywardnet.com/inground/products/filters/sand.cfm
Posted on Apr 14, 2010
  • 3 Answers
SOURCE: how do i change the
Hello, 1 You need to unscrew the drain plug and screen (if it is still there!) at the base of the filter. 2 You can reclaim most of the sand by letting the filter drain through a sieve (lots of work) or use new sand. 3 Uncouple union joints or couplers that attach to filter head. 4 Remove filter head. 5 You can try pulling some sand out of the top. However, do not damage the filter fingers in the sand. 6 Use a hose to blast the sand out the bottom drain. 7 Inspect all fingers, replace if necessary. 8 After all is cleaned out, place finger mount inside filter. Cover top of mount with a cup or similar to keep the new sand out of the finger assembly. 9 Replace drain plug and screen. 10 Fill filter halfway with water. 11 Slowly pour sand in and spread evenly. 12 Remove mount cover. 13 Reinstall head, unions and couplings. 14 Prime pump and test for leaks.
Good Luck
Posted on May 14, 2011
  • 17 Answers
SOURCE: do you have a hookup
The model #711 is a 1.5" valve, not the filter. The following link is for the top mount filters in the pro series http://www.hayward-pool.com/prd/Above-Ground-Pool-Sand-Filters-Pro-Series-Top-Mount-Systems_10201_10551_15009_-1_24001_14018_A.htm
Posted on Jul 21, 2011
Can you rebuild a 711 Hayward
all the filter heads can be rebuilt. there are no kits for this that i know of but the individual parts can be ordered in. i usually just replace the entire head for $400
May 30, 2014 | Hayward SAND FILTER, PRO SERIES
What size of sand filter hayward s711
711 is the style of valve head and goes onto many different sizes of filter body. there is usually a tag on the filter body to indicate the size as well as how much sand to use for that filter. if that tag is missing, measure the diameter of the filter body as, again, that will let you find the information you need
Apr 30, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward sp 711 txc
Your diverter "spider" gasket needs to be changed. It is underneath the handle.
Aug 18, 2013 | Hayward Pool & Spa
MANUAL FOR HAYWARD 711 SAND FILTER
contact Hayward they will send you a PDF
Jun 24, 2012 | Hayward SAND FILTER, PRO SERIES
We have a hayward sand filter model sp 711 13 for our vinyl lined pool. We are having alot of trouble getting the pool to clear up. When we opened it for the season, it cleared up great and was running...
How long is it since the sand in the filter was changed? How long has it been installed? If the water is clean but cloudy, get some kind of flocculant from your pool supplier. Follow the instructions carefully as your pool will need to be bavkwashed on a frequent basis.
Regards alshipman@gmail.com
Jun 27, 2011 | Hayward Pro Series Sand Filter -36" Tank
Hayward S180t filter w/ hayward sp 711 multiport valve. I removed to multiport valve to fix the spider gasket. I didn't think to mark so I could put the multiport valve back on. I need to know how to put...
Hayward 711A13 Vari flow valve. When I push down the handle to move valve into other settings the handle does not want to relock into the next setting. I have to manually pull up un the back of the handle and tap with my hand to get spring to retract. What can I do to lubricate this sping inside?
Apr 28, 2010 | Hayward SAND FILTER, PRO SERIES
I need to change the sand in a hayward model 711 sand filtration system. Are there any instructions for this out there?
Apr 08, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
75 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
