Question about ACCO 28-Sheet Commercial Electric Two-Hole Punch, Fixed 1/4" Holes, Platinu
How to release paper from jam? - ACCO 28-Sheet Commercial Electric Two-Hole Punch, Fixed 1/4" Holes, Platinu
ESP Office 2150 all-in-one
Shows paper jam. no paper in machine
Apr 11, 2016 | Kodak Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I have a paper jammed in the printer and I cannot get it out.
Normally the paaper gets jammed into the rollers and the drives and could be easily released if you can use the copy keys to forward the drive.There could be also paper lodged in the feed rollers or the inner roller could have jammed into. If so you will have to release the holding screws of the roller and remove off the paper. If the dispaly is showing paper jammed there is also the possibility that the paper detect in optocoupler sensor is faulty. If so check and replace this which is found at the paper feed on. Once the display shows a release the printer should work . Hope you try out. Good day
Jul 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam message...but no paper is jamming system
is a small finger plastic, stucked on the paper path, release-it and problem solved. (Is very fragile, so use a small tool to release)
Dec 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
Aug 01, 2009 | Brother HL-2070N Laser Printer
Jammed paper
Removed the new paper from feed slot, pressed the on button which allowed the `grabber` to release the jammed paper slightly and then was able to [with the aid of long tweezers] remove the jammed paper through the feed slot.
Regards
Geoff
Feb 04, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
ACCO 28-Sheet Commercial Electric Two-Hole Punch, Fixed 1/4" Holes, Platinu Logo
334 people viewed this question
Top ACCO Office Equipment & Supplies Experts
jasbo
jasbo
Are you an ACCO Office Equipment and Supply Expert? Answer questions, earn points and help others
