Question about Sony Cyber-Shot DSC-W650 Digital Camera Black
Why can't i get my Sony Cybershot camera to import pictures onto computer via USB
The USB cable is working properly so it's not that.
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony Cybershot W55 digital camera- needs proper USB connector.
Hello Voyager2Lcat,
You need Multi-Use Terminal Cable for DSC-W55 and its Sony Part Number is 1-829-866-51
Picture is attached as reference.
Posted on May 27, 2008
ginko
  • 19396 Answers
SOURCE: Can't import pictures from my sony cybershot dcsw70 camera
Try replacing the data cable.
Try replacing the Pro Duo Memory stick, or use a card reader to test the memory card.
Test the camera on a different USB port, and then on a different computer.
This can tell you if the problem is the computer or the camera.
If the problem is the camera , then the USB data port may be defective.
If the problem is computer, try doing a system restore to a date before problem started.
If that does not help you may need to reinstall the system.
Posted on May 16, 2009
Can't download pictures to my computer from my Sony Cybershot W330
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 25, 2012 | Sony Cybershot Dsc-w330 14.1 Mp Digital...
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
I bought a toshiba, have not used my sony cybershot 1.3 till today, only to find I cannot download my pictures because my driver is not installed.
The easiest alternative method to transfer the pictures onto your computer is to remove the memory card and plug it into a card reader (either built in or a USB card reader if you have one). If not, you can connect your camera to your computer by the USB cable.
Once you plug the camera or the card in, Windows will usually ask you if you want to import the images. You can do that or import them manually by opening up the SD card or camera in my computer and dragging the files to the folder you want to store them in.
Otherwise please post your exact Sony Cybershot model and the version of Windows on your Toshiba and we can try to find you the correct software.
Please leave feedback if this was helpful. Thanks.
Apr 11, 2011 | Toshiba Cameras
IMPORTING PICTURE FILES FROM MY SONY CYBERSHOT DSC650 TO MY MACINTOSH COMPUTER??? -- MY CAMERA IS CONNECTED TO MY COMPUTER VIA THE USB CABLE. --THE CAMERA SAYS "USB MODE PTP" --I DO NOT HAVE ANY...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program, such as iPhoto.
Oct 20, 2010 | Sony Cybershot S650 Digital Camera
My sony cyber shot does not get connected via usb to system
[Click here to Download*]
Description
Thisdriver download for Sony digital cameras will work on most Windowssystems and Cybershot digital cameras. This is a USB driver and in caseyou are not familiar with the general approach to installing drivers,it is important that you follow these steps:
  1. Download the Sony driver
  2. Make sure that the USB cable and digital camera are NOT connected to your PC
  3. Install the digital camera driver
  4. Do not try to plug the camera into your PC until you have finished installing the driver and restarted your computer.
Thisprocess may take an extra few minutes, but it helps prevent problemsand ensure the Sony digital camera driver is properly installed. Afterrestarting, the driver will let you transfer files via USB. Simply plugin your Sony camera and you should be ready to go.
Oct 17, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cybershot 4.1 mp camera I accidently deleted the software to automatically download my pixs on to my pc.How to I get the software????
Description
This driver download for Sony digital cameras will work on most Windows systems and Cybershot digital cameras. This is a USB driver and in case you are not familiar with the general approach to installing drivers, it is important that you follow these steps:
This process may take an extra few minutes, but it helps prevent problems and ensure the Sony digital camera driver is properly installed. After restarting, the driver will let you transfer files via USB. Simply plug in your Sony camera and you should be ready to go.
Oct 16, 2009 | Cameras
May 13, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Hello Voyager2Lcat,
May 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I can no longer download the photos from my cybershot onto my pc
Plug the USB lead directly into the computer, not via a hub
Jun 05, 2017 | Sony Cybershot S650 Digital Camera
Sony Cyber-Shot DSC-W650 Digital Camera Black Logo
16 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
