Question about McCulloch Garden
MAC3200 IGNITION CIL SETTING - McCulloch Garden
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
Please rephrase your answer in the form of a question.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Posted on Feb 19, 2018
Having trouble getting spark on a Suzuki 250 4 stroke 91 to 93 change cil an got new spark slug .
Does it have points, an inductive pickup, or CDI ignition? If points, see if there is enough gap to get a spark. In time, the insulated part that rubs on the points-cam wears down and that closes the points. Just a thought..
Sep 24, 2016 | Suzuki Motorcycles
Tip
How to Reinstall a Distributor if Crankshaft Moved.
Applys to all Distributor Engines.
Follow this easy instruccions if you want to reinstall a distributor on a vehicle where the crankshaft was moved from the position it was when the distributor was removed.
Remove #1 spark plug
Place your finger over the spark plug hole while turning the engine with a wrench on the pulley bolt at the front of the engine.
When you feel compression continue turning the crankshaft slowly until the timing mark on the vibration damper is aligned with the "0" on the engine timing indicator.
Position the disttributor rotor between the number 1 & 8 (for 8 Cil.) 1 & 6 (for 6 Cil.) or 1 & 4 (for 4 Cil.) spark plug terminals on the cap.
Lower Dist. into engine. To set the gear on the bottom of the distribuitor, you may need to turn the rotor a little bit. If the distributor does not drop down flush against the block is because the distributor shaft has not mated the oil pump shaft, if this happens, place a large socket w/braker bar on the crankshaft bolt and turn the engine over in the normal direction of rotation until the two shafts engage properly and the distributor sits flush against block.
With the base of the distributor properly seated, turn dist. housing to align the marks you made in dist. base and engine block. (you did make this marks before removal right? : )
Place the hold down clamp and install the hold down bolt not too tight.
Install dist. cap an reconect electrical plugs, spark plug wires, etc.
Check ignition timing and when set, tighten dist. hold down bolt.
on Apr 20, 2010 | Chevrolet 1500 Cars & Trucks
Replace ignition coil instructions
Not sure what you are doing but removing the ignition coils is pretty simple. Unplug the coil. Use a 7mm socket to remove the bolt that holds the cil in place. Remove the coil. Some of the coils require a 7mm swivel socket. Not any swivel socket will work. I know for sure that a snap-on or Mac brand swivel socket will work. I also know a craftsman swivel socket will not. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 20, 2012 | 2006 Lincoln Navigator
Change my ignition cap and rotor but now it doesnt start the engine
Make sure the distributor cap and ignition wires are on correctly .If there're not it will not start.
Jan 15, 2012 | 1992 Mazda MX-3
I want to know engine size of my camry 1998 i.e 2.0 L Or 2.2
if your corola is 4 cil. is 2.2 L.
but if, is 6 cil. your engine is 3.0 lit.
Sep 10, 2010 | 1998 Toyota Camry
Could it be a fuse in electrial engine fuse that is why my car won't start the ignition just turns no kind of catch. we start it fron in motor no problem so its not the battery.
mcdevito75 here, There should be no fuse keeping your car from starting, possible causes, fuel pump bad, ignition modeule bad, cil pcks if equipped bad. Have your shop check it out.
Jun 18, 2010 | 1996 Volkswagen Jetta
2.5 tdi 5 cil. is good?
Audi A6 2,5 TDI 5 cil is a great car. The engine is one of Audi's most tested engines. But models before '96 will rust quite a bit, if you dont look af it. So look for rust and be sure that the drive-belt is replaced in time.
Feb 09, 2010 | 1995 Audi A6
Theres no spark
Hi and welcome to FixYa,
A couple of initial checks using a voltmeter:
  • IGN + 12VDC on the red/white wires going to the ignition coils and the TCI;
  • pulsating voltage on the orange and gray wires coming from the TCI going to the ignition coils when starting;
  • ensure that the black wire is tied to the ground;
  • low pulsating voltage between orange & black and the gray & black coming from the pick-up cil connector going to the TCI when starting.
Postback results of tests.
Good luck and thank you for asking FixYa. Happy Holidays.
Dec 16, 2009 | 1985 Yamaha XJ 700 S Maxim
Garden Logo
14 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
