Swamp cooler thermostat - Heating & Cooling
Ed Phillips
  • 11 Answers
SOURCE: Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Posted on May 31, 2009
Ed Phillips
  • 11 Answers
SOURCE: Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
Posted on Jun 20, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
  • 233 Answers
SOURCE: Swamp cooler starts up automatically after power outage
generally ther thermostat is the "brain" of the system, check the wiring diagram (if there is one) or the wiring and see if the on off swtch is inseries or parallell to the thermostat, (should usually be in series if it is I would say that the on off switch is the culprit. you cna verify with an ohmmeter to see if it is staying in the closed position.
Posted on Jul 19, 2009
mrjfisher
  • 141 Answers
SOURCE: Got an Adobe Air Swamp Cooler Model # P228101A. Lo...
Indoor Comfort Evap Cooler & AC Parts, Phoenix AZ 85021 2001 W Cheryl Dr, Phoenix, AZ 85021
www.merchantcircle.com › ... › AZPhoenix85021
They say they have parts for your unit.
Posted on May 19, 2010
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
Jul 18, 2009 | Heating & Cooling
PARTS FOR A ADOBE AIR
Need the part that holds the pads.
Jun 30, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
