Question about Canon PIXMA MP600 all-In-One InkJet Printer
Failed Wireless Setup/could not create new port
Pixma620. Vista 64 bit system. New computer. New printer. Repeated attempts to install wireless, fail. Repeatedly get message "new port could not be created." Have followed recommendations here without success.
Do I need to install the 64 bit drivers from Canon site? If so, which 64 bit driver (one is labelled "for network", the other just Vista 64 bit). And if so, at what point do I install this driver (before, after software installation?).
Any help would be apprciated
  • chemoose Jun 23, 2009
    Sorry, but the link would not allow me access.
    The printer came with a complete "getting started" installation guide as well as a Network Setup troubleshooting guide. I used these in detail. Unfortunately even in the troubleshooting guide, the only suggestion for "fixing" the "new port could not be created" error, was to uninstall the MP drivers (I did) and then repeat the installation setup (which does reinstall the drivers). Multi attempts brought back to the same error.
    THANK YOU! Following your directions (exactly), the wireless setup was completed and is now up and running properly. :)
  • 2,178 Answers
Check this link for wireless setup:
http://downloads.canon.com/MP620/Intro_to_MP620_Setup_Guide.htm
There are Vista 64 drivers on the CD that came with the printer, but if you want to download, you should download the network drivers if you are installing the printer to work on a wireless local area network (LAN).
Posted on Jun 23, 2009
  • old marine
    old marine Jun 23, 2009
    Try this. Uninstall the drivers using the Uninstall option from the program list. Look for the IJ Network Utility program listing, and in there use the Uninstall option for the Scan Utility and the Network Tool. Look on the CD for the following file: \CANON_IJ\win\LAN\English\CNMNPU.exe, and double click on it. (This uninstalls the network port that was originally set up for the printer).
    Now, with the printer disconnected until prompted, try the setup and installation again.
Thank you for writing to us. We value you as a Canon customer and
apologize for the installation difficulties you have had with your PIXMA
MX340.
Uninstalling and reinstalling the network port and printer driver should
resolve this issue. To perform the uninstall, please have the PIXMA
MX340's CDROM in the CDROM drive and then follow these steps:
1. Click on Start and then Run.
2. Click Browse. In the browse window, on the left hand side in the
row of big icons, click on My Computer.
3. In the window to the right, double click the printer CDROM named
CANON_IJ.
4. Double click the folder named WIN.
5. Double click the folders named Driver and then DrvSetup.
6. Double click the file named DELDRV. In the Run box click ok.
7. Click Execute to start uninstall and Yes to completely uninstall
the drivers.
8. Once finished, click on Start and then Run.
9. Click Browse. In the browse window, on the left hand side in the
10. In the window to the right, double click the printer CDROM named
CANON_IJ.
11. Double click the folders named WIN, DRIVER and then LAN.
12. Double click the file named CNMNPU.exe
13. In the Run box click OK and then Yes on the Delete BJNP Port
window.
14. The uninstaller will prompt you to restart the computer, please
click Yes to restart the computer.
Once the printer has been uninstalled, restart the computer.
When the computer restarts, please make sure to disable any firewall or
anti-spyware programs currently installed. Then we will reinstall. To
do so, please follow these steps:
1. Turn your PIXMA MX340 off.
2. Insert the CDROM that came with the unit. The setup program will
start automatically.
3. If the Autoplay screen appears, click Run and then Continue.
4. Click on Custom Install.
5. When the Custom Install screen appears, Check the MP Drivers/MX340
Drivers and the Canon IJ Network Tool.
6. Read the License Agreement carefully and click Yes if you agree.
7. When the Setup Method appears, choose Printer is already connected
to the network.
8. Click Next.
9. When the Printer Connection screen appears, connect the PIXMA MX340
to the computer using the USB cable and turn on the PIXMA MX340.
10. Click Next on the Setup Preparations screen.
11. When the Access Points screen appears, select an access point to
use and then click Connect.
12. If the Set Printer IP Address screen appears, click Connect.
13. If the Network Setup of Card Slot window appears, click Next.
14. When the Setup Completion dialog box appears, disconnect the USB
cable and then click Next.
15. On the Connection Performance Measurement screen, click Next.
16. Confirm the results and then click Finish to complete the
installation.
Once this process is complete, try printing to test the connection with
the unit.
Please let us know if we can be of any further assistance with your
PIXMA MX340.
Thank you for choosing Canon.
Sincerely,
Michael
Technical Support Representative
Posted on Feb 13, 2011
  • Jesus El Oct 05, 2013
    I'm using Win7 64 with a Canon Pixma MG315 and was having this same problem. I followed your instructions above, and whilst they were for Vista I managed to improvise where required and now have a fully working wifi printer. What I would like to know though is; WHY SO DIFFICULT IN THE FIRST PLACE???? This should really be plug n play, but this has taken me more than 2 hours to install. Because of that, when this Canon unit dies I'll be going back to Brother. Your Canon website is also ZERO help in this matter.
    Correction!!! Model is MG3150
Epson workforce 840 all-in-one. Driver installation fails.
Check the compatibility of the driver with the OS version:Windows 8 (32 or 64 bits), Windows 7 (32 bits or 64 bits) , Vista (32 b, 64 b), XP (32 bits , 64 bits). You should try to use the software that shipped with the printer. When installing, choose local printer (USB), or Network (Ethernet cable, or Wireless).
Oct 31, 2013 | Epson RX595 Photo All-In-One Printer
Driver for TOSHIBA e-studio 280 - windows 7 64 bit
This driver works for me on our Users 64 bit Win 7 Machines. Installed as local printer.
Win XP/2003/Vista/7/2003/2008 64 Bit PCL6 12/22/10 4.5.98.0
http://business.toshiba.com/support/downloads.jsp?site=usa
If networked create a new port and enter the printer IP.
Apr 17, 2012 | Toshiba Office Equipment & Supplies
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
Setup stops at printserver will connect to your wireless network
hi
thank you for using Fxiya
go to folowing link you will find complet stup for Linksys printserver
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
May 15, 2010 | Linksys WPSM54G Print Server
I have a new computer and it says that I cannot install this printer on the new computer
DRIVERS
click on the Printer
HP Officejet Pro 8500 All-in-One Printer - A909a
HP Officejet Pro 8500 Premier All-in-One Printer - A909n
HP Officejet Pro 8500 Wireless All-in-One Printer - A909g
for following Operating System
» Microsoft Windows 7 (32-bit)
» Microsoft Windows 7 (64-bit)
» Microsoft Windows Server 2008 x64
» Microsoft Windows Server 2008 W32
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
» Microsoft Windows XP» Microsoft Windows Server 2003
» Microsoft Windows Server 2003 64-Bit Edition
» Microsoft Windows 2000 Server
» Microsoft Windows XP x64
» Mac OS X
» Linux
Jan 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer Sharing for 32os and 64os
I am not sure I follow. If you are attempting to share a printer over a home network between computers with different OSes, perhaps you could try this:
If the printer works already with Win7(32bit), go to the Vista computer and try the following:
Go to Control Panel. Choose printer. Then choose Add Printer. Choose Add a local printer. Click on Create a new port. The default in the drop down box is Local Port. Do not change that. Click Next.
A dialogue box will appear asking for you to enter a port name. Type in the \\computer name\printer name
Dec 05, 2009 | Computers & Internet
Selecting a printer that works with my PC.
Get the printer specification and purchase any printer that has what you want that specifices that it has a driver for the windows (Which) 64 bit system. Xp?  VISTA? NT?
Mar 11, 2009 | Dell Inspiron 530 Desktop Computer
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Sep 01, 2008 | Office Equipment & Supplies
Canon PIXMA MP600 all-In-One InkJet Printer Logo
6,699 people viewed this question
old marine
old marine
