Question about Pioneer Televison & Video
Pioneer DVD-V555 DVD tray will not open.
When the open button is pushed it says open but does not seem to do anything. After a few seconds it switches to say stop. The same thing happens when using the open option on the remote.
SOURCE: stuck in 'set 1'
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Posted on Jan 22, 2008
SOURCE: Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Posted on Feb 21, 2008
Wilcox1976
SOURCE: DVD Eject tray stuck
Your problem is more than likely mechanical. There is a belt that makes connection between the motor and the loading mechanism. Take the unit apart. Remove the belt it is probably in the front. Clean the belt and pullies with denatured alcohol. reassemble. The best solution is to replace the belt but this may get you working till you get one. Belt sources http://www.mcmelectronics.com/
please visit my eBay webpage
http://members.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=wilcox1976
Posted on May 15, 2008
SOURCE: disc tray will not open and standby indicator is flashing
I can't get the tray to close
Posted on Jul 04, 2008
djicenova
  • 319 Answers
SOURCE: DVD player disc tray won't open
loader mechanism has malfunctioned and is not user serviceable at a reasonable cost. replacing this unit would be your best bet
Posted on Mar 19, 2009
Hi, I wonder if anybody can help me with a problem with my DV-717 DVD Player?
Hard question: Have you considered opening it to see what mechanism is doing and also to make sure something that does not belong inside got there in the mechanism?
I have seen where somehow a second disc got inserted and if the mechanism jams for any reason odd issues and or shutdown may happen.
Apr 09, 2012 | Pioneer Televison & Video
When I press any button on the DVD player the word Flash Sum keep blinking and nothing works.
this shows that the microprocessor in the motherboard seems to be defective hence its advisable to reprogramme or change the entire motherboard then programme again. this will completely provide the solution
Sep 16, 2011 | Pioneer DVD-V555 DVD Player
Dvd tray not opening properly
You just simply replace the rubber wheel of an open / close motor. how to fix this: open the cover of the DVD and turn it on DVD, press the open button when the DVD tray out, you can see where the location of the rubber. The rubber usually has no more tense, not strong enough to pull and push the DVD tray.
Jul 26, 2010 | LG Televison & Video
Tray won't stay open
My unit closed immediately upon opening since like 1 day after the warranty ran out. It bothered me. I finally tore it apart and this fixed it.
Take the cover off. As you are facing the front of the player, the blue sensor switch that controls the tray will be on your left in the middle of the carousel. Push button to open tray and locate it as the tray opens. Grab the tray and also the carousel and hold them so you can see the little blue switch. Use a tiny screwdriver or toothpick or other slender device to "flick" the switch fully forward and backward several times. Let go of the tray and try the button. If it still closes immediately, repeat the flicking. Try it again.
Jul 09, 2009 | Pioneer XV-HTD520 Multi-disc DVD Player
I cannot open the dvd tray all that appears on screen when I try is "tray lock"
I FOUND THE ANSWER ON YOUR PROBLEM PAGE, HOLD THE OPEN/CLOSE BUTTON FOR AT LEAST 10 SECONDS AND THE TRAY WILL OPEN
THANK YOU VERY MUCH FOR THE SOLUTION
Nov 30, 2008 | Pioneer Televison & Video
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Pioneer htz-77dv Tray Lock
We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
Jan 19, 2008 | Pioneer HTZ-77DV System
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Televison & Video Logo
42 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
