Question about LG WM-2277HW Front Load Washer
Change default settings? - LG WM-2277HW Front Load Washer
How do you change the default stitch length for the straight stitch.
A setting change while you are sewing should not happen. Sounds like you will have to take your machine in for service.
Apr 11, 2015 | Janome Memory Craft 9000 Computerized...
HOW TO SETT DEFAULT SETTING
Default setting should already be set, as default. Any changes you make will change the default setting. If you need to go back to default setting you can factory reset which sets back to default setting.
Default
Oct 14, 2014 | Cell Phones
Change default font
Outlook Express 4.0, 4.01
  1. In Outlook Express, click Stationery on the Tools menu.
  2. To change the font settings for e-mail messages, click the Mail tab, and then click Font Settings.
  3. Change the appropriate font settings, and then click OK.
  4. To change the font settings for newsgroup messages, click the News tab, and then click Font Settings.
  5. Change the appropriate font settings, click OK, and then click OK.
Outlook Express 5
  1. In Outlook Express, click Options on the Tools menu.
  2. On the Compose tab, click Font Settings.
OLEXP How to Change the Default Font in Outlook Express
Aug 05, 2014 | Dell Computers & Internet
Change default font in word 2013
Click File > Options > General. Change the default font in "When creating new workbooks"
Mar 29, 2014 | Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
Jan 06, 2011 | HP Photosmart C7280 Printer
I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
Restoring the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
Use the
(SELECT).
2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
Use the
press (SELECT).
The device automatically restarts.
Then you need to change the default settings back to what they were.
Oct 19, 2010 | HP Color LaserJet 2600n Printer
Windows Mail does not revert to default print settings
see if you have done change in ti or try to reinstall it!!
Aug 13, 2009 | Microsoft Office Outlook 2007 for PC
Want to change default settings for scan
change the size, then utility/counter - > choose user settings - initial settings and use current settings.
should work,
May 27, 2008 | Konica Minolta bizhub C351 All-In-One...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
LG WM-2277HW Front Load Washer Logo
13 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
