Question about Koolatron 18 Bottle Dual Zone Wine Cooler
My wine cellar doesn't cool - Koolatron 18 Bottle Dual Zone Wine Cooler
    New Friend:
After I did some search, it seems to be easy to repair this kind of problem on Refrigeration system that doesn't use a compressor. How those units cool down temperature is by using something called "Peltier Effect". It is a little piece of electronic between two hot sink. This little piece of Electronic has one side that cool and one side that heat. This piece is named a "Peltier". If the power supply doesn't have any problem, simply be unmounting the Heat Sink and changing the "Peltier" plate should do the job. Actually, any kind of refrigeration system that doesn't have a compressor and use this technique to cool/warm can be repaired by simply replacing this piece. The reason is tha it is somewhat sensible if the temperature of the piece is getting to hot. When that happen, one most reason is that there is no sufficient air flow behind the appliance allowing it to cool down the "Peltier". In short, just change the "Peltier"!!! About 5$ - 15$ buck repair!!! :P This is considering that the fan and thermostat are working well!
Enjoy!
Posted on Apr 06, 2017
    New Friend:
Since november2014 I'd tried having my koolatron 18 bottles cellar repair . no parts aviable no koolatron assistance and when i'd phone no answer. that' s SCRAP ...
Posted on Jun 02, 2015
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Cooling unit is running, but interior is not cool.
How long have you had this unit and did it quit suddenly or did it fail intermittently. Do you mean running where you can hear the fan and the light comes on when you open the wine cellar door? If so, I would suspect the starting relay failure on your cooler which should be very easy to replace. There should be a wiring diragram on the back of your unit somewhere and could be labeled (RT). Your compressor would be the last thing I would suspect.
Dec 05, 2010 | Vintage Keeper 500 Plus Wine Cellar
My wine cellar (Model: ow0912H6H) still runs but it does not cool. What can I do? I don't believe that there is a compresser in ot. I don't know what cools it.
I had the same problem and noticed that the lint screen behind the cooler was full of lint where it was almost completely clogged. I vacummed it and it seems to have done the trick.
Feb 19, 2010 | Oster 12-Bottle Wine Cellar - Black
My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Kitchenaid Wine Cellar-model # KUWS2246EBLO Power on switch does not turn on cooling compressor. Lite will come on.
Try tapping on the thermostat it is probably sticking.
If it comes on then you will need to replace the thermostat.
Check the start relay on the compressor.
Check the fan motor on the compressor is it running?
Clean lint from underneath on the condensing coil.
Mar 26, 2009 | KitchenAid 48-bottle Wine Cellar
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
Koolatron 18 Bottle Dual Zone Wine Cooler Logo
1,453 people viewed this question
Top Koolatron Furniture Experts
ray gallant
John Mangan
John Mangan
Tom Chichester
Are you a Koolatron Furniture Expert? Answer questions, earn points and help others
