Question about McCulloch Mcc1635a 16-inch 35cc 2-cycle Gas-powered Chain Saw
I purchased the saw about 6 years ago and the auto oiler gear stripped and I'm trying to locate a replacement shaft and gear.
The ID in the side of the saw is 36cc, MS1636NAV, but the info on the label above the handle is MS42,42cc, family 4MHXS.0424AAEM
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Did you check ebay for any of those numbers ?
Posted on Jul 03, 2016
4 Suggested Answers
rtpflh
  • 546 Answers
SOURCE: I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Posted on Sep 21, 2009
  • 4088 Answers
SOURCE: need to locate chain & bar oiler adjustment
Look to the lower left side of the bar (as you hold the saw normally)--there should be a screw head in the engine case there. Check the adjustment by holding the bar tip at speed near a piece of cardboard for a couple of moments--it should throw off a thin line of oil. Hope this helps!
Posted on May 02, 2010
Biggdex35
  • 333 Answers
SOURCE: I have a McCulloch MS1636NAV chain saw. The engine
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Posted on Oct 05, 2010
Stihl chainsaw (Farm Boss) - chain oiler has stopped working, how do I check the fault ?
Hi John...
You will need to remove the bar and chain...behind the bar is the auto oiler it works on the shaft of the chainsaw, you will have to remove it and clean all the outlets for the oil to the chain.
Please take time to rate me
Bud
Mar 10, 2013 | Garden
Ihave never been able to get the automatic oiler to work on a Poulan Wikd Thing 18" chainsaw. I have replaced the spring drive, bought a spacer tool for the spring drive, replaced the plastic gear,...
It is a fairly simple oil pump system, the spring gear on the crank will fit on either way, however the spacing of the coils is is critical, there is a small plastic tool to do this, i think you said you had this tool, it has to be an issue with the pump, the gear not only turns but has a throw, the amount of throw denotes the amount of oil delivered, a small steel pin in the side of the pump body works in a cut a way in the pump shaft, has the pin fallen out? just cant think what else you can do as you seem to have done everthing.
Apr 12, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler not working
replace the oiler assembly
nylon gear frequently strips gears
replacements only cost around $10.00
Sep 10, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Gear Case, Auto-Oiler screws are stripped and i need the part number for the screws. they are double threaded meaning one side screws into the gear case and the other end is threaded to recieve nuts that...
You give no model number. If you had I would have opened the parts manual and located your part number. You can find it here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Echo Garden
McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
Lou
Apr 30, 2010 | McCulloch Garden
Auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | Homelite Garden
I have a problem with a Remington electric pole saw
Shall we remain friends or shall I be honest? The only thing RemingtomPower is creating today is unhappy customers. They shutdown manufacturing some time back and replacement parts are exhausted.
RemingtonPower.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter "111409" in the "Search for your unit by Model #:" window. Click “Search” Click "View Model" Click "View Illustrated Parts Diagram"
From reading the IPL the motor is a sealed unit. You can probably drill off the rivit heads and access the interior. I suspect if done you'll find defective gears. You probably won't find any source for replacement gears.
Here comes the honesty. It was a bad design from the onset. There is no bar and chain lubrication and most drive components are plastic. Locating a manual oiler on a component 10 feet above your head is no better. How do you compute operating cost if every 2 years it must be replaced?
I recommend you purchase a name brand replacement, from a company you expect to be in business 5-10 years from now when you require replacement parts. A lower initial purchase price isn't always the best bargain.
Sorry to be the bearer of bad news but think you already knew it was time for a replacement. I provided a very good answer to your question and should not be punished for RemingtonPower's failure. Sorry
Lou
Nov 02, 2009 | Remington Polesaw Wizard
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Bar oiler problem, replacing plunger did not fix the problem
the worm gear is on the plunger.the gear that is on the crank shaft,if i remember is a nylon gear.some times they look prefectly fine but they slip on the crank shaft and do not trun the worm gear fast enough to oil. here is a parts breakdown for that saw......http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401904.pdf look on page four 4.......i hope this helps,let me know........................
May 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Oct 22, 2008 | Husqvarna Chain Saw 20" Bar
McCulloch Mcc1635a 16-inch 35cc 2-cycle Gas-powered Chain Saw Logo
71 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
