Question about LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator
What could be preventing the air filter cover of my refrigerator from moving?
I need to change the air filter inside my LG French door for the first time. After watching the you tube video, as well as reading and following the written directions I am unable to turn the cover at all. It won't budge. budge.
  • 641 Answers
You may want to try this site.
Filters Fast Water and Air Filter Experts
Posted on May 13, 2014
Where and how do i change air filter for Kenmore 79673059410 refrigerator?
LG French Door Refrigerator - Replacing the Fresh Air Filter ...
? 1:26
https://www.youtube.com/watch?v=ziaCjNIPSCU
Dec 11, 2012 - Uploaded by ExperienceLG
LG French Door Refrigerator - Replacing the Fresh Air Filter ....DO NOT GET THIS FRIDGE UNLESS THIS ISSUE IS FIXED!!!! We've had this ...
Jan 12, 2016 | Kenmore Refrigerators
I have lg french door refrigerator lfx21976st pull cold air but does not freeze in the freezer
Inspect back panel in the freezer section. Is it covered in frost?
Feb 01, 2015 | LG Refrigerators
LG French door refrigerator bottom freezer not working
Check inside vents are clear and door seal is good. Check air compressor area is clean and well ventilated. Put setting in a low number and turn off / unplug unit, count to 10 and plug in, turn on.
Crossing fingers helps too ;)
Mar 30, 2014 | LG 7841 Bottom Freezer French Door...
How to fix light not going off in refrigerator
Replace the main pc board. Was part # 6871JK1011C, with a 5 amp light relay, now should use the new board, part # 6871JK10011F, with a 16 amp light relay, which will prevent relay contacts from welding themselves together. Should also replace the lamp socket harness with part # 6621JK2003B which now has a thermostat on it to prevent lamp from overheating and melting lamp cover. Contact a locally authorized LG servicer or LG directly to have the servicer replace this for free, even though technically it is out of warranty, LG will cover the repair. (servicer may need an authorization code to get credit from LG)
Mar 16, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRFD25850 French Door Fridge set at 37-40 c keeps freezing produce at back or in large bottom drawer
Pull the drawers put and cover the cold air vent (small hole at back wall) with tape ...problem solved!
Jan 08, 2010 | LG LRFD25850 French Door Refrigerator
Lights stay on inside Sears (really LG) french door refrigerator
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Dec 10, 2009 | LG LRFD25850 French Door Refrigerator
I have a LG refrigerator LFX25980n with FF failure, how to fix?
Is the freezer cold, but the refrigerator part is not cold?
If so, "FF" probably means fan failure. The fan which moves cold air from the freezer to the refrigerator is not working properly. The fix is to replace this fan.
Oct 09, 2009 | LG 24.7 cu ft Panorama French Door...
What is the function of thermal fuse and how can i check it
In your case I believe you are talking about a thermal overload located on the compressor and inside the wiring cover. The compressor has one on the inside also. If compressor can't start normally the overload cut the power to compressor to prevent damage. If this in happening frequently then we need to find out what is going on. Let me know, Thanks, Sea Breeze
Apr 08, 2009 | LG LRFD25850 French Door Refrigerator
LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
150 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
