Question about Breville ESP8XL Espresso Machine
My breville light keeps blinking and maing a noise
The right side is stuckin the up position and all the lights keep blinking.
The physical mechanism is probably stuck. open the toaster and clear it.
Mar 04, 2016 | Breville BTA840XL 4-Slice Toaster
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
How stop watetfull light keeps blinking.
empty condensate water resivour and power off and back on
Sep 09, 2014 | Soleus Air P-MA9000AH-008 Remote Control...
My Breville Expresso machine does nothing when I turn dial to make coffee
Sounds like its time to clean it. Run white vinegar and a little water through it.
Apr 18, 2012 | Breville Coffee Makers & Espresso Machines
My machine blinking on steam, the wand does not want t o steam, the espresso does not pour. The knob is turned on stand by , but still some steaming noise comes, but no steam comes from the wand, nor...
When it is blinking on steam it means it is preparing the unit for steam. When the steam light goes solid your unit is ready to make steam.
  • Turn from standby to steam then wait for steam light to go solid.
  • When solid steam wand will begin dribbling then spitting out water, which will then turn to steam.
  • When it begins to steam, turn back to standby. NOTE: you only have 6 seconds before steaming turns off.
  • place steaming wand in jug and turn from standby back to steam.
You will hear pumping noises when you turn off your steam, because it releases the steam and puts the excess water in to the drip tray.
  • make sure your bean hopper is properly locked in to the unit. Grinder won't work if hopper not locked in.
  • Make sure your water filter has been prepped and locked securely in to the reservoir and your reservoir is filled.
  • Use fresh beans.
  • Sounds funny but use good quality water, do not use ordinary tap water. Make sure it is filtered or use bottled water (cooler bottles).
  • Try to grind your beans to a good consistancy.
  • Breville recomends about 10kg tamping pressure, use a set of scales to check the feel.
  • Tamp to about 3-5 mm below rim of grouphead (portafilter). Or the tamp has a guide on the side, that silver side on the tamp is the tamp line. Pretty vauge about that in the book.
If all else fails go to www.breville.com.au and check your model and watch some of the vid clips.
Jan 06, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Steam function on the BES400 just stopped working! its been working fine for about 10 months & now the light just continues to blink, no pressure, no steam!
I have the same problem. Mine is 2 yrs old. Boiler is OK, just no steam. I opened it up and the controller board has a blown elecolytic cap. However, after replacing this still no steam. I would guess it needs a new controller board. I will try Breville...
Dec 07, 2010 | Breville BES400 Espresso Machine
Broiler not working
my water will not get hot the light just keeps blinking
Jul 31, 2008 | Breville Die Cast 800ESXL Espresso Machine
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
FixmeBob Great help with Breville 800esxl
I had a similar problem, but no blinking light, only cold coffee. I tapped on the relay (black box on circuit board) and violá.  Red light, hot coffee, and happiness.  The machine did the same thing a couple of weeks after the "fix", and a good slap to the left side, and I was back in business.  My guess is that your switch is bad or sticking.  Good luck.
Feb 06, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville ESP8XL Espresso Machine Logo
21 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
