Question about Thetford Norcold DE0051 Refrigerator
Norcold de251e t-stat lost part off the board
The test guide tell me the t-stat is bad it only has one on -off switch two res. a l.e.d and a 10k pot. But look like a part came off from the coner of the board where it says r/f . This fridge is in a friends boat I think bounceing around may have helped lose the part. If i could look at a schematic I can fix it. thanks
THE HIGH TEMP.LIMIT SWITCH IS OPEN NEED LOCATION
The high temp switch connects to your power board at "Limit In" and "Limit Out". Follow those wires to the switch. I would see if you're under the Norcold recall. Give them a call and check. If you're not, here is where you can get an upgraded thermal switch:
Norcold High Temperature Limit Switch V2 0 by ARPrv
Apr 24, 2016 | Norcold Inc Norcold 1210IM Refrigerator
RESISTAN VALUE OF R522,R524 ON THE INVERTER BOARD BA71F0F01041.
Hi Juan,
the resistor values you want are:
R52
RES METALIZED FILM T 1/4W F 3.92k?
R524
CARBON RES. 1/4W J 10k?
The complete Service Manual is available as a .pdf Here:
Sylvania LC420SS8 LCD TV Service Manual
Its free to view, but you'll have to agree to a free 14 day trial membership to download it. Hope this helps you,
Jan 22, 2016 | Sylvania LC420SS8 LCD TV
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold Ice Maker wont work
check water line if ok check water solenoid see if voltage if so replace solenoid if not bad board
Dec 15, 2013 | Thetford Norcold RV Cooler/Freezer
Norcold n811 120v heating element test
on board check 12 volt element and 120 volt element if voltage to it bad element if none bad board
Jan 22, 2013 | Thetford Norcold RV Cooler/Freezer
I have a Arcoaire Gas Furnace (Model# GNJ100N12A1), that will not fire up. It has a White Rogers Digital Stat. First the Stat seems to be faulty, since it reads 70plus in a house that has a temp of 30...
Sounds like a faulty board. shut the power to the furnace off for a minute then turn it back on. Make a call for heat at the thermostat. The inducer should start and close contacts on a pressure switch . Once pressure switch closes the hot surface ignitor should glow red. Then the gas valve will open when the gas valve opens you should get fire till the stat is satisfied. If your concerned it is the jump out r to w on the board this will eliminate the stat. If you to reset the rollout switchs 3 timesyou're getting flame rollout and you either have a cracked heat exchanger or blockage in the exhaust piping or a bad inducer motor. Keep me posted with what you find!
Dec 15, 2010 | Heating & Cooling
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
Volume control pot is bad. Tagged VR1 on PC
Before you replace the pot, try cleaning it. Use electrical contact cleaner such as:
- CRC QD Electrical Contact Cleaner (available at many auto supply stores) - www.crcindustries.com
- Caig DeoxIT (available at Radio Shack and electronics supply stores) - www.caig.com/
Spray the cleaner liberally in the pot (spray where the shaft meets the pot, and if possible, into any holes on the back of the pot), and rotate the shaft repeatedly. Repeat several times.
If the pot is still intermittent, it can be replaced, but you need to replace it with a compatible part, and the job will require some soldering skills to prevent damaging the rest of the circuit.
Make sure you get an appropriate replacement. You need a replacement pot with the correct resistance (measured in ohms) and taper (linear or analog). Typically, the value of the pot is marked on the back, and will read something like "103A" or "10K - B". 103 or 10K indicate the resistance in ohms, and "A" or "B" indicate whether it is linear or audio, respectively.
Your best bet is to desolder the part and take it to a local electronics store for a replacement. If no store is available locally, replacements can be ordered from online stores such as:
- Mouser.com
- Jameco.com
- Digikey.com
Feel free to post the numbers on the back of the pot if you need help locating an appropriate replacement.
(Note that the convention for labeling taper has changed over time - getting the wrong taper should not damage the equipment, but will probably result in the volume control to seem "not smooth.")
Nov 02, 2009 | Boss Music
How to diagnose a bad water pump
Not that big a job, to pull the t-stat and test it in hot water in the house.
If you have a candy thermometer and a large pot, suspend the stat in the water via string, heat the water and observe if the stat opens up.
If yes, the at what temp, most are between 170-190 degrees?
If not then you have at least one suspect.
You can also button up the Ford and start it up, does it still over heat without the stat?
Even with the engine cold the pump should still circulate water.
Either way the fastest method is to turn a few wrenches to get a suspect stat out to test.
If you have a cooling issue when was the last time you changed fuild and/or did a superflush of the cooling system?
Aug 06, 2009 | 1993 Ford Ranger SuperCab
Thetford Norcold DE0051 Refrigerator Logo
563 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
