Question about IBM ThinkPad T20 2647 Notebook
IBM T20,inaccessible boot device
My can't startup my IBMT20.The stop error screen appeared and It shows" inaccesible boot device"How to to reset my boot device since I don't have any CD or user manual...
    Scholar:
  • 122 Answers
The Innaccessable Boot Device message means one of 2 things:
1: your hard drive has died - not much here, must replace drive.
2: The master boot record has become corrupt. Without any media, this will be hard to fix. You will need to boot to the Windows CD and either run the recovery console or perform a windows repair to fix this issue.
Posted on Jun 23, 2009
I have an IBM T20 and when I start it up, the screen does not come on, don't hear hard disk working, but the fan is working. There is beeping when started - 3 beeps, then follow by 3 beeps, and then 1...
That is likely. The beeps represent an error code. You might try borrowing an external monitor plugged into your laptop to see if anything shows on that screen when it boots up.
Sep 15, 2010 | IBM ThinkPad T20 Notebook
IBM Thinkpad T20 .when you press F1 for bios setup utility it shows you that it is waiting for bios setup utility it will show this message on the screen for a long time without showing any other problem...
you need to reset the bios, which means opening the machine up and starting up with the motherboard battery removed. then replace the battery and boot as normal.
Jul 24, 2010 | IBM ThinkPad T20 Notebook
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
My ibm T20
your computer is full of virus better install a anti-virus and scan your computer for virus and delete them.
Jan 26, 2008 | IBM ThinkPad T20 2647 Notebook
Operating system not found, hard disk not found message showing in IBMT20
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
356 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
