Question about Home
Evap purge tubes for a 2013 chrysler 200 - Home
  • 184 Answers
SOURCE: P0441 Evap control system purge flow fault
http://www.obd-codes.com/p0441
and
http://www.obd-codes.com/p0455
Posted on Sep 05, 2009
  • 20 Answers
SOURCE: Describe your EVAP Purge Solenoid Circuit Fault
Try going to http://www.ls2.com/boggs/dtcs/DTC%20P0443.htm
Posted on Nov 08, 2009
SOURCE: "Check Engine light"
The issue is that the system randomly checks the loop of the fuel system to confirm that it has no leaks. A missing cap is the easy one to correct. It might also be a slpit in the rubber hose that connects the fuel fill tube (on the chassis) to the one on the tank, or any other hose in the the entire fuel delivery/ fume recovery sysrtem. The solenoid that allows the engine's vacuum to be used to conduct this test can also be sticking so that after the test cycle, it doesn't reclose. Good luck
Posted on Dec 10, 2009
emissionwiz
  • 80339 Answers
SOURCE: Where is the interior fuse panel located in a 2013
Under the dash on the drivers side.
Posted on Apr 26, 2014
paulmacin18247
  • 3218 Answers
SOURCE: Chrysler 200 2013 no heat on the passenger side but heat on the drivers side
Suspect inoperative blend door actuator/motor not working properly. There are several actuators attached to the heater box assembly that control air flow direction and heat/cold operation. Some are easily accessable while others are labor intensive to access.
Posted on Jan 20, 2016
Where is purge valve solenoid located?
Mar 16, 2014 - 2 posts - ‎1 author
I have a 2003 Vue 3.0L 2wd.After fueling I have trouble starting, it cranks but I have to pump it a couple of time then it starts, Sometimes after it ... 2008 Saturn Vue Purge valve canister solenoid location ...
Aug 24, 2013
access to vent valve solenoid - SaturnFans.com Forums
Jan 20, 2013
Service engine soon light: P0440 - SaturnFans.com Forums
Apr 15, 2010
Code P0446 (evap solenoid) and now I can't fill the gas ...
Nov 17, 2007
More results from www.saturnfans.com
EVAP Solenoid Location - YouTube
? 2:17
https://www.youtube.com/watch?v=jIKaPF2Yw3I
Mar 20, 2007 - Uploaded by richpin06a
Saturn EVAP Solenoid Location. ... How To Test and Replace EVAP Canister Vent Control Valve P0446 - Duration: 6:18. by CarsNToys ...
EVAP Purge Solenoid Removal - YouTube
Dec 11, 2015 | 2003 Saturn VUE
What does code p1447 mean ...???
The code says "evap purge flow monitor fault"
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless.
Feb 15, 2013 | 1996 Nissan Maxima
2000 Ford Focus...DTC code PO455
code PO455
EVAP Control System Large Leak Detected
Possible Causes:
Aftermarket EVAP hardware non-conforming to specifications Canister vent (CV) solenoid stuck open EVAP canister purge valve stuck closed, or canister damaged EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged Fuel filler cap missing, loose (not tightened) or the wrong part Loose fuel vapor hose/tube connections to EVAP components Purge sensor or FTP sensor is out of calibration or has failed I would say that your gas cap is a good place to start.
Apr 25, 2012 | 2000 Ford Focus
Common causes for codes p0441
getting code p441 could be caused by evap purge solenoid vacuum line loose leaking or restricted, evap purge solenoid faulty, evap purge vacuum line to canister leaking or disconnected,evap canister failed.
Feb 06, 2012 | 2001 Chrysler 300M
Describe your Problemcheck engine light codes p0457 p0455
Trouble code P0455-EVAP Control System Large Leak Detected
Trouble Code Conditions:
ECT sensor less than 90°F at startup, engine running, and the PCM detected several small fuel vapor leaks or a large leak in the system.
Possible Causes:
  • Aftermarket EVAP hardware non-conforming to specifications
  • Canister vent (CV) solenoid stuck open
  • EVAP canister purge valve stuck closed, or canister damaged
  • EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged
  • Fuel filler cap missing, loose (not tightened) or the wrong part
  • Loose fuel vapor hose/tube connections to EVAP components
  • Purge sensor or FTP sensor is out of calibration or has failed
Jan 22, 2011 | 2006 Ford Explorer
Codigo p1440
EVAP System Vent Circuit Malfunction
This diagnosis detects leaks in the Evaporative Emission (EVAP) purge line using of vapor pressure in the fuel tank. The EVAP canister vent control valve is closed to shut the EVAP purge line. The vacuum cut valve bypass valve will then be opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP control system pressure sensor can now monitor the pressure inside the fuel tank. If pressure increases, the Engine Control Module (ECM) will check for leaks in the line between the vacuum cut valve and EVAP canister purge volume control solenoid valve.
Possible causes
- Incorrect fuel tank vacuum relief valve
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve
- Foreign matter caught in EVAP canister vent control valve
- EVAP canister or fuel tank leaks
- EVAP purge line (pipe and rubber tube) leaks
- EVAP purge line rubber tube bent
- Blocked or bent rubber tube to EVAP control system pressure sensor
- Loose or disconnected rubber tube
- EVAP canister vent control valve and the circuit
- O-ring of EVAP canister vent control valve is missing or damaged
- EVAP canister is saturated with water
- Absolute pressure sensor
Possible solution
- Loose fuel filler cap
- Leaking fuel filler cap
Hope helps (remember to rate this answer).
Jan 05, 2011 | 2000 Hyundai Sonata
Obd-2 code p1455
DTC P1455 - Substantial Leak or Blockage in Evaporative Emission Control System
The PCM monitors the complete EVAP control system for no purge flow, the presence of a large fuel vapor leak or multiple small fuel vapor leaks. The system failure occurs when no purge flow (attributed to fuel vapor blockages or restrictions), a large fuel vapor leak or multiple fuel vapor leaks are detected by the EVAP running loss monitor test with the engine running (but not at idle).
Check this possible causes:
After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
Damaged EVAP canister
Damaged or missing fuel filler cap
Insufficient fuel filler cap installation
Loose fuel vapor hose/tube connections to EVAP system components
Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
Mechanically inoperative fuel tank pressure (FTP) sensor
Check for audible vacuum noise or significant fuel odor in the engine compartment or near the EVAP canister and fuel tank
Tell us news.
Jul 19, 2010 | 1996 Ford Explorer
I had an emission test done on my 98 bonneville and it failed because code P0440 evap control system what should i do ?
Here's list why your car is coming up with this code. It could be any of these things causing it.
DTC detecting condition:
  • EVAP control system has a leak.
  • EVAP control system does not operate properly.
Possible cause:
  • Incorrect fuel tank vacuum relief valve
  • Incorrect fuel filler cap used
  • Fuel filler cap remains open or fails to close.
  • Foreign matter caught in fuel filler cap.
  • Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve.
  • Foreign matter caught in EVAP canister vent control valve.
  • EVAP canister or fuel tank leaks
  • EVAP purge line (pipe and rubber tube) leaks
  • EVAP purge line rubber tube bent
  • Blocked or bent rubber tube to EVAP control system pressure sensor
  • Loose or disconnected rubber tube
  • EVAP canister vent control valve and the circuit
  • EVAP canister purge volume control solenoid valve
  • EVAP canister purge volume control solenoid valve and the circuit
  • Absolute pressure sensor
  • Fuel tank temperature sensor
  • O-ring of EVAP canister vent control valve is missing or damaged
  • Water separator
  • EVAP canister is saturated with water
  • EVAP control system pressure sensor
  • Refueling control valve
  • ORVR system leaks
  • Fuel level sensor and the circuit
Apr 01, 2010 | 1998 Pontiac Bonneville
I have a 2004 Chrysler Town and Country and my
P0440:
  • Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
  • Inspect the EVAP system for cuts/holes in tubes/hoses
  • Inspect for damaged or disconnected hoses around the Evap purge solenoid
  • Check and/or replace the sensor
  • Check and/or replace the purge valve
  • Have a professional use a smoke machine to detect leaks
  • P0441:
    Bad vacuum switch
    • Broken or damaged EVAP line or canister
    • Open in PCM purge command circuit
    • Open or short in Voltage feed circuit to Purge Solenoid
    • Faulty purge solenoid
    • Restriction in EVAP solenoid, line or canister
    • Corrosion or resistance in purge connector
    • Bad PCM
    Dec 21, 2009 | 2004 Chrysler Town & Country
    Home Logo
    66 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
