Question about Vehicle Parts & Accessories
Locksmith ign wont turn
    Master:
  • 710 Answers
Make sure you use the correct key.
Posted on Aug 31, 2014
Lost IGN and door keys for 2004 Chrysler 300 M. Dealer can cut door key but won't start car. Must get car to dealer for key, Any options?
some locksmiths with the right stuff can make you a key that will work. finding one might be a challenge.
Jan 08, 2018 | Chrysler Cars & Trucks
My only ign.key with chip won't start car.the chip is out .can you make new one using Vin. Num
Not on a model that old. Most dealers only keep key codes for 3 years.
A dealer or locksmith can find the right code for the chip using a scanner, but you would have to take the car to them.
A locksmith may be able to determine what the chip was in the old key, but I doubt it.
Jan 20, 2016 | 1990 Cadillac Deville
Have no ign lights,engine turns over but wont start
Have you checked the battery terminals? sounds like they are dirty/corroded causing no power to starter.
Dec 16, 2015 | Cars & Trucks
How do you replace ign lock cylinder on a 2003 jaguar x type if the key wont go in the cylinder
You may have to resort to the dealer or a locksmith authorized to work on Jags. Removal of the ignition cylinder requires the use of the key to enable you to rotate the cylinder for removal from the housing. This is a safety/ anti theft feature built into the design.
Feb 17, 2015 | 2003 Jaguar X-Type
I cannot get the key to turn to acc been trying for 5 days now
Probably dropped a tumbler inside ign. cyl. Call a reputable locksmith to replace it or take it to the shop.
Sep 14, 2010 | 2000 Toyota Camry
I tried turning the key & wheel at the same time to unlock the anti theft mechanism, do i need to turn it that hard? i dont wont to break it!
you may need a new ign lock cylinder, common problem. you will need to turn the key ON to get the cylinder out, or it will need to be drilled out. Call a locksmith, I'm sure he knows about them.
Oct 15, 2009 | 2001 Ford Focus
98 Toyota 4Runner ignition switch won't turn
turn key toacc using pick release ign cyl start car w long pliers while having locksmith repair cyl
Mar 06, 2009 | 1998 Toyota 4Runner
Truck wont start
with an assistant near the key switch, get under truck and, using a rubber mallet or block of wood, turn the key and strike the starter nearest the large solenoid (identified by a usually round cylinder about 2 inches in diameter and with at least one large and one small wire attached). The solenoid "piston" needs lubrication, but this will get you started for now, assuming you have tested all electrical connections to starter/battery
Jan 28, 2009 | 2004 Ford F150
Ignition switch replacement 1983 monte carlo
you have to take off the steering wheel.if you dont have the right tools to do so i would not attempt it.the turn signal switch has to be moved it just pulls over the end of the column.then there is a torx head screw at about 1 oclock in the column that has to be removed.and the ign.just pulls out.the dimmer switch is kinda tricky.a locksmith usually dont charge to much to do this job.it would probably cost you more to buy the tools you need to do it yourself
Nov 16, 2008 | 1987 Chevrolet Monte Carlo
Key wont turn to lock position for the steering wheel?
Auto trans must be in park if it is then I believe a relay or switch has failed. Check owner manual for possible fuse.
Sep 06, 2008 | 2000 Dodge Stratus
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
