Question about Epson TM T88 Thermal Printer
Not printing condensed mode in foxpro dos mode
Sir i have purchased a epson tm88iv printer but now i have found that it is printing only on normal mode it is not printing in condensed mode i.e. like we used to print in dot matrix command like chr(15) for condensed mode but it is not working in this printer can you solve my problem
thanks
from kailash puri
email: kp_meera@yahoo.in
date:23/6/2009
SOURCE: Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Posted on Dec 03, 2007
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
SOURCE: foxpro dos programme not printingin usb printer laserjet cp1515
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Posted on Jan 22, 2009
  • 415 Answers
SOURCE: i have dot matrix printer and i want print a letter in 12.5 cpi
follow the link
http://www.epson.com/pdf/LQ2180.pdf
This is the manual.
Mark
Posted on Apr 01, 2009
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Posted on Dec 02, 2009
I am using dos based foxpro application in widows xp. when ever i take print from epson Fx 2175. the print job is paused at last line until i close the application. please rectify.clarify,...
Many DOS programs were designed to write directly to the printer's buffer, rather than to a spooler like more modern applications. It sounds like FoxPro is doing exactly that - and isn't designed to release the job until being completely closed.
Mar 06, 2011 | Epson FX 2170 Matrix Printer
Foxpro 2.5 Application can't direct print in xp cause in my print Dot Matrix with Epson LQ-2180 using USB to Pararel Port...
share the printer then search for your own computer and you should be able to open it and see the shared printer like. \\server\printer
then use net use command...
net use lpt2: \\server\printer /Persistent:yes
then tell foxpro to print out lpt2 and it will act like dos
you can add net use command to autoexec.bat or windows startup if you will do this often
Nov 08, 2009 | Electronics - Others
Tally Genicom Slow Printing in Foxpro Dos Program
change the connecting cable serial or parallel what you have it may help you.
Jun 15, 2009 | TallyGenicom 2280 Matrix Printer
Dos command print in USB printer
Try this.
You can share the printer and then run a command like:
net use lpt1: \\servername\printername
I think you can go one step further even and add /persistent to the end to make it more permenant.
This will allow your program to send a print job to lpt1.
If you need further explanation of this let me know.
Good Luck
Mar 20, 2009 | Office Equipment & Supplies
EPSON LQ 1150 Roman letter two last two Can not print in foxpro
best way to come out of this problem is to fire your printing using an batch file
ex.
set print to scrn.txt
set prin on
? 'hello'
? 'welcome to fast printing'
set prin off
set prin to
run fastprin
create fastprin.bat file
edit fastprin.bat
@echo off
type scrn.txt >PRN
then execute the above program
Mar 04, 2009 | Epson LQ1170 Matrix Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos programme not printingin usb printer laserjet cp1515
Try
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
What is the command for networking printer for foxpro in dos ?
you can do this thru printer maping
try this DOS command
net use LPT1 \\computer name\printer
Dec 15, 2008 | Computers & Internet
Problem with the epson lx 300
Try to reinstall the printer diver
Aug 12, 2008 | Epson LX-300 Matrix Printer
Epson TM T88 Thermal Printer Logo
297 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
