Question about Panasonic Audio Players & Recorders
My panasonic 5 disc sl-pc364 the turn table will not turn
Why does my turntable not turn and the disc reader will not raise
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
  • 104 Answers
SOURCE: How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Posted on Feb 11, 2009
DJ Wildman
  • 10 Answers
SOURCE: Technics SL-DZ 1200
Upgrade the firmware. you need a small SD card.
I forget what keys to hold down at power up.. or where to download the update
BUT.. it may work.. I am sure you can find it..
Or maybe you have gunk on the tracking servo's gears "linear' a grain of grit.
working on the DZ is easy if you have any electronics background.
Posted on Jul 11, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Posted on Nov 28, 2009
SOURCE: Technics SL-5 Turntable will not turn.
now iam using the technics sl-5 turntable.it is tonearm damaged.
replacement tonearm are available? or pl inform tonearm model number
Posted on May 12, 2010
How do i install a belt on technics turntable sl-bd22
If you remove the rubber pad, you should be able to grasp the metal table. A gentle tap onto the center spindle while pulling up on the table should release the table. Place the new belt onto the underside of the table. Replace the table onto the spindle. Then feed the belt over the motor hub.
Dan
Apr 20, 2011 | Technics SL-BD22 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
I got a panasonic atomotive turntable - ser.no. SL-HM42. I require a needel for above
Check online. There are plenty of places that sell needles for turn tables!
Dec 03, 2010 | Panasonic Audio Players & Recorders
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Technics SL-DZ 1200
More than likely the traverse assembly needs to be replaced. Unfortunately, this is not easy, as Panasonic does not sell this assembly complete. YOu will have to purchase each part individually, and this in itself is not an easy task. Only an service tech knowledgeable with this unit will be able to help you out with this. Unfortunately, I cannot refer you to anyone in Taiwan.
Panasonic service is useless all over the world. I have never heard of a good repair story about Panasonic, so it's good that they didn't attempt the repair. Go with a independent reputable local service center.
Your always welcomed to ship it to us here in NY. But it wont' be cheap, and there could be more damage to the unit during transit. Just a suggestion though, if you can't find anyone in your area.
- Davis
DJ Pro Audio
www.djproaudio.com
www.djprolab.com
Jul 12, 2008 | Technics SL-DZ1200 Turntable
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
Panasonic turntable sl h205
Check the belt and the cueing mech, could have siezed.
John w
Feb 12, 2008 | Audio Players & Recorders
No audo/no disc
Do you receive any disc errors? Or does it just not even load/accept the disc? If it does accept it, do you hear the cd turning?
Make sure you dont have anything jammed in there. The only thing that would cause this is a faulty drive, which should only be replaced by a qualified service technician. The part itself is roughly a $70-100 part.
- TWEAK A/V LAB
Nov 03, 2007 | Panasonic Technics SL-DZ1200 Turntable
37 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
