Question about Blanco 510-876 wave Undermount Sink Stainless Steel
Where can i find a stopper for blanco 510876 - Blanco 510-876 wave Undermount Sink Stainless Steel
The strainer/stopper is stuck in the kitchen sink the sink has a disposal unit attached. How do I remove it from the top
We just experienced the problem describe in this question. A dinner guest pushed the strainer stopper past the Blanco flange over the disposer and the stopper could not be removed by pulling straight up. The Blanco flange is difficult to remove so we knew that removing the flange would be a last ditch effort. I tried using several tools trying to deform the stopper enough to lift past the lower part of the flange but without success. While I was on the internet looking for a solution, my wife found the obvious answer. She pushed the stopper down into the disposer, rotated it 90 degrees. She then aligned the edges of the stopper with two of the small indents in the lower part of the flange. The stopper was then pulled up past the flange where only two points on the circumference of the stopper contacted the flange.
Kudos to her for this simple solution.
Sep 24, 2012 | Blanco Sink Waste Strainer / Stopper...
The stopper on the waste strainer has disappeared and a replacement strainer is not readily available in UK. Is there a way of repairing the existing strainer as I cannot recall what the mechanism was...
Get a "FIT ALL" basket for now just to make it so you can use the sink, and most people will never see it . Order a new strainer that fits, They might send you just the one complete system
The thing that happend is your hoping to get everything done.. Dont let that upset you .
It will take a week or two. But you have a working sink and let Blanco worry. They will do what ever they need to.
I hope this works out for you Be safe and be happy,
Thanks for using our service
Tom
If you could take a second or two and rate us, this way we can better understand what we need to do better. thanks again
Sep 10, 2011 | Blanco Sink Waste Strainer / Stopper...
I purchased a Blanco waste strainer #441099. It is brown plastic for a granite kitchen sink. My plumber could not use it. said it didn't have a ring that holds the disposal flange. There is a groove...
This strainer is not for a garbage disposal. The strainer for the garbage disposal comes with the disposal. If you bought two of these for the sink, then that's why you have one left. The disposal has its own.
Jul 23, 2011 | Blanco Sink Waste Strainer / Stopper...
The rubber washer on the stainless steel plug has perished and therefore will not hold water in sink when needed.
Unless its really old, you should be able to find a replacement stopper at HD or local plumbing supply.
Apr 30, 2011 | Blanco Sink Waste Strainer / Stopper...
My strainer/stopper is stuck in kitchen sink drain. How to remove it?
If it's not visible from above then you must remove the trap j-bend. Go under the sink and put a big bowl or tray under the trap because when you remove the j-bend water will come out. You'll need a 12" grooved pliers, like channel locks, to get the nuts off. There are two of them. If the trap is old brass or chrome you may end up cracking the j-bend. If it's white or black plastic you can probably remove the nuts by hand. Look in the j and pull out your stopper. If it's visible from above a long pair of needle nose pliers would work best to remove the stopper.
Jan 31, 2011 | Blanco Sink Waste Strainer / Stopper...
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Jan 17, 2011 | Blanco Sink Waste Strainer / Stopper...
Do i need to use plumbers putty with the blanco strainer and silgranit sink
No I use a small bead of clear silicone... if any squeezes out just let it bead and set up ...after it dries just trim it off with a sharp knife...
works great!!! and looks even better ...
heatman101
Sep 08, 2010 | Blanco Sink Waste Strainer / Stopper...
Blanco 510-876 wave Undermount Sink Stainless Steel Logo
105 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
