Question about Tools & Hardware - Others
How to paint a wall? - Tools & Hardware - Others
    Problem Solver:
  • 8 Answers
Using a brush, paint all edges carefully, around doors, windows, under ceiling scocia etc then use roller to do rest, roll top 2 bottom not just ramdom
Posted on Apr 26, 2016
    Problem Solver:
  • 14 Answers
Before I answer, I need more info.
Please be specific. Tell me about the room, (size, windows, doors, trim, panels, color you want, condition of walls and ceiling, be as specific as possible. I have 30 years experience, and can be very clear with enough info!
Good Luck, and look forward to hearing back
Neil
Posted on Sep 27, 2014
Can you use ultra white paint as a primer on a wall before painting it?
Not recommended, especially if the ultra white paint is anything but "flat." Primer is designed specifically to adhere to other paints. Look into KILZ primer (if it is available where you are), as I have found it to provide excellent coverage for color changes.
May 08, 2015 | Tools & Hardware - Others
Tip
Painting patterns using stencils
Painting a pattern on your wall can be very difficult if you want all the shapes to be the same size and level. But just like when you were little and had letter or shape stencils to help you draw perfect drawings, you can make stencils yourself for what ever it is that you want to paint on the wall.
Using a sheet of cardboard or a contact sheet draw and cut out the shape that you want to paint. If you want to make a pattern that goes all the way around the room then you should make two or three stencils so you can level them.
To use the stencils first prepare the wall you want to paint, you want to paint the base color before you use the stencil because painting around your design can be very challenging. When the wall is dry take your stencil and using painters tape, tape the stencil to the wall so it doesn't move. Making sure that you don't over load the paintbrush paint inside the stencil trying to be careful around the edges. When you finish filling the stencil carefully lift it off, make sure that there isn't any paint on the underside of the stencil because if there is and its wet it will leave unwanted marks on the wall.
Repeat the process of taping, painting and lifting until you have finished painting your pattern on the wall. When you are finished step back and enjoy your handiwork.
on Oct 24, 2013 | Crafts & Hobbies
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
Oil from a reed diffuser spilled all down my bathroom wall on Benjamin Moore paint how can I remove the oil thT stained the painted wall
I would wipe it down with a degreaser like Simple Green, or paint thinner
The paint is ruin after cleaning it you will need to paint. You can prime the area with a oil base white primer in an spray can
Jul 23, 2014 | Tools & Hardware - Others
What can i do to fix peeling paint on a wall?
scrape, sand, Prime with an acrylic primer ,skim texture and top coat
or call a professional
Jun 25, 2014 | Tools & Hardware - Others
Paint scratches off easily on drywall
You can find good colours for painting your wall and good durable paints and follow it with the help of interior designers. They provide plenty of samples and designs for your requirement and guide you. They use many fabric paintings, hand painted wall papers, laminated multi coloured wall papers with different textures. For further ideas and assistance you can contact them at http://www.interiordesign.net/. Homepage Interior Design
Feb 18, 2014 | Dutch Boy Int Drywall Pva Primer By Dutch
A newly painted wall looks splochy, shinny in some spots and dull in others.
I would hope that you had the paint mixed well before putting it on and that the entire wall was done in one event. Also it would be of help to have primed the existing paint first.
Oct 21, 2013 | Computers & Internet
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    Tools & Hardware - Others Logo
    91 people viewed this question
    Top Tools & Hardware - Others Experts
    J.D. Browning
    J.D. Browning
    Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
