Question about Frigidaire FRA25ESU2 Air Conditioner
Is the drain hole drectly under the condenser? Also, I want to attach a drain hose to the drain hole. Is there a fitting available?
2 Suggested Answers
  • 308 Answers
SOURCE: how do i connect drain hose ---it is on the
That is exactly what you have to do. If you ever decide to just use the bucket, you will have to buy a hose cap, but they are relatively inexpensive. Hope this helps
Posted on Oct 05, 2009
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Ice builds up on bottom of side by side freezer. can't tell if drain isn't working right or fi there is just to much water from some source--condensation, leak etc
Hi this is the drain, clean the ice out run bleach water through the drain make sure it, drains, you should be fine.
Sean
Mar 27, 2011 | GE Refrigerators
I have a dou therm A/C unit model #03869and it appears to have a blocked drain[it is raining]inside!!! what do I have to do to unclog drain
The tray below the evaporator has a drain tray with a drain hole to fit in a hose. Due to high level off dirt accumulation it is possible that the tray drain is clogged and prevent the condensed water to flow out. Open the unit and look under the panel to find this, use a thin flexible cord to push into this drain hole to clear it. You can also use a good air jet with the flexible nozzle pointed to the hole to push out the dirt.
Aug 30, 2010 | Dometic Rooftop RV Air Conditioner
Have water on the floorboard when aircondtion on
The air conditioner will remove water from the air. There is a drain line from the bottom of the exchanger under the dash that should have a hose attached to it running the condensed water out of the car. This hose has probably come loose. Look under the dash for fittings and hoses that are not connected to each other or take it to a shop and explain this problem to them.
Aug 18, 2010 | 2000 Mitsubishi Galant
Air conditioner condensation dripping into the floor.
Check the drain hose, chances are it came loose from the fitting on the AC unit. Make sure the hose goes through the floor board.
Jul 17, 2010 | 1997 Jeep Grand Cherokee
I own2001 Dodge Cummins Diesel truck. My vent
Pull the blower fan motor out from under the dash on the passenger side, wash the box out with a water hose, then attach a piece of rubber hose over nipple that comes out of drain about 1" longer. Your condensate water is draining back inside truck through nipple to carpet padding
www.txdashcovers.com
Jan 20, 2010 | 2001 Dodge Ram 2500 Truck
There is water on passenger side front and rear
There is a rubber drain hose that should be attached to the bottom of the cooling/ blower unit on the passenger side of the car underneath the dash. This hose drains the condensation from the cooling unit. the hose may have gotten disconnected or it may be clogged up. I have had cases where a dirt dobber built a nest up inside the hose and clogged it up. Check this hose it may be the cause of the water puddling up in your car.
Aug 28, 2009 | 1997 Toyota Camry
Need manual with exploded diagram
If your model has a condensate (water) reservoir, there should either be a threaded hose fitting located at the bottom of the reservoir that will accept a standard garden hose, once you punch out the plug inside the threaded coupler.
If you do not have a threaded hose coupler on your unit's reservoir, remove the reservoir and look inside the area above it and there should be a small hose fitting that you can attach a standard garden hose to, to allow for constant draining without having to use and empty the condensate reservoir daily, etc.
If you don't have either of these items, you'll need to purchase a new condensate reservoir with a hose drain attachment to allow use of an auxillary drain hose. You'll need to contact Maytag customer service for the correct parts and assistance.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(866)616-2601 U.S.
(800)688-2002 Canada
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | Maytag M7DH45B2A Dehumidifier
How do i hook up plastic attachment so i am able to run a hose to a drain for continual usuage DH404E
Most brands have a fitting molded into the drain pan that will let you attach a garden hose to the tank. You may have to drill a hole in the fitting to allow the water to drain through.
Aug 18, 2009 | Goldstar DH304 Dehumidifier
I purchased a LG Dehumidifier MODEL LHD45EL and I followed instructions to attach a hose to it for the drain. I removed the drain hole cover and I don't see a drain hole connector or a hole to install it...
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Jul 22, 2008 | Maytag M7DH45B2A Dehumidifier
Frigidaire FRA25ESU2 Air Conditioner Logo
19 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
