Question about Toro Lawn Boy Self Propelled CARB Walk Power Mower
How to tighten drive belt on Honda mower HRR216 series mower?
2 Suggested Answers
  • 6468 Answers
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
Posted on Mar 29, 2012
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
How to adjust the Governor on Honda Engine
Automatic governor. Replace or rebuild carb. Ensure float is functioning properly..
May 30, 2014 | Honda Genuine oem harmony ii hrr216...
Where is fuel filter on honda hrr216 mower?
It should be connected inline with the fuel line.
May 12, 2014 | Garden
Drive belt comes out
There is an adjustment to tighten up the drive belt tensioner pulley. You should be able too see it after you remove the safety shield. Tighten adjustment nut to snug belt.
Apr 20, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
My honda HRR216VXA will not work.
Hi there are 3 model transmissions and looks like assy only i would check the belt first you can check it out at this web site called pats small engines.
Jun 06, 2009 | Garden
Toro Lawn Boy Self Propelled CARB Walk Power Mower Logo
79 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
