Pioneer sa 8100
PROTECTION LIGHT GOES ON AFTER A CERTAIN LEVEL OF VOLUME??
SOURCE: Kenwood VR-405
you have some wire touching or cross.
Posted on Jun 09, 2008
jerryg50
  • 1667 Answers
SOURCE: i have this pioneer receiver
Check to see that the electrolytic capacitors that are in the output stage circuits and driver stage circuits are not high in ESR.
Check to see that the power supply is in specs. The main electrolytic caps may not be up to specs. To test the power supply it is best to run a load test on it. You will need the proper setup for this.
The supply current to the output stage may be high, and thus causing the protection to turn on. You will need to have the service manual for details.
It is also possible that the speakers are too low impedance, or their crossovers are going defective and causing a miss-match for their loading impedance.
Look with a scope to see that there are no high frequency oscillations in the output of the amp going to the speakers. A common cause of this type of fault are worn de-coupler caps in the bias circuits for the various stages along the signal path.
Check to see that there is no DC out to the speakers with any position of the volume control with no signal going in. The speakers must be disconnected for this test. Do the same with a sine-wave signal from the test generator. 1 kHz is good to use for this test. Use a proper rated 8 ohm dummy load for your amplifier when applying the test signal. Do not put steady strong tone in to your speakers. You will have to refer to the service manual to know the allowable DC offset at the output stage to the speaker terminals. Most consumer amplifiers must be less than 50 mv. The higher end amplifiers are down to less than 10 mv.
It is also good to do a distortion test to see if there is too high a distortion that is causing the protection to trip.
You can also use the dummy load and the audio generator along with the scope to do power handling tests. This gets involved to put over this type of email.
These are only some basic examples of what to check. You will need the service manual, a scope, ESR meter, DVM, audio generator, and distortion analyzer to go through all the tests to find out where the fault is.
Jerry G.
Posted on Jul 08, 2008
tech48
  • 624 Answers
SOURCE: Receiver goes into protect mode when hitting certain volume level
There is a problem in one of the output channels of the amplifier. That is the only reason it will do this. I work at an authorized Denon service center and have seen this problem several times, but it has never been the same thing that causes it. It has always resulted in extensive troubleshooting to find the problem. One time it was a capacitor in the pre-driver circuit for one of the channels, another time it was a transistor in the same type of circuit. I can not remember all the other causes. But without the proper tools and the knowledge of how to troubleshoot an amplifier circuit you will never figure it out.
Since this is an older model, more than 3 years old, it is no longer under warranty. They get a 2 year warranty from Denon. You can take it to any service center that works on stereo equipment and they should be able to fix it for a reasonable fee. Probable around $125 to $150 depending on their rates. It may seem like a lot, but it is much cheaper than buying a new one.
Since this is really the only option for you, unless you have the tools and knowledge, a FixYa! would be much appreciated and appropriate.
If you would like to troubleshoot it yourself, let me know, I have the service manual in PDF and can email it to you if you like and help you with troubleshooting it. But be aware, it is not an easy job.
Dave
Posted on Nov 10, 2008
dunnbiker
  • 8546 Answers
SOURCE: when you are watching a
Loose speaker wire somewhere or heat.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 26, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a pioneer sa-8100
Could be a lot of things. More triage is needed.
Have you done any isolation to prove/disprove a certain source, channel cable or speaker are NOT the problem first?
Posted on May 26, 2011
I have technics tx 30 amp wen turn up volume it goes into protection
Sounds like you should put the fan back then doesn't it.....?
Jan 04, 2014 | Pioneer GM-X524 Car Audio Amplifier
I have a pioneer sa-8100 amp. Left channel goes off shortly after playing it. What is wrong?
May 26, 2011 | Pioneer Audio Players & Recorders
ZX10001 Car Audio Amplifier: i have a zx 200.2 powering four pioneer 6x8's in m...
any mosfet transistor amplifier shares two on each side, so if you re running four speakers on a two channel amp you are running at less than 1 ohm, only certain amps can run at 1 ohm stable, protection mode is a precausion, so if its happening you are pushing it too hard, carefull you are punching pure DC into your speakers and soon one if them will give way... good luck
May 03, 2010 | Car Audio & Video
My protection light keeps turning on.
i'm almost positive that your amp is overheating. i would either buy another one or bring it in to the geek squad. but i'm 99.9% sure it's overheating
Apr 28, 2010 | Kicker ZX10001 Car Audio Amplifier
On my Sony Surround Sound tuner, if I raise the volume up to a certain level (not that loud), I get a flashing sign ''protect'' and the sound to the speakers are cut.
Sony has protection in these receivers for two main reasons.
1 - Checking for DC voltages on the outputs to speakers. Not your particular problem.
2 - Excessive current being drawn from receiver on one or more of the speakers.
Number 2 should be your starting point in finding a solution. Put the volume level on Medium - 35 to 40 on the front panel. Now listen to all you speakers in turn. Any scratching noise will indicate a defective speaker. Remove this speaker from the receiver output and check again if the set goes into protection on high volume.
If you could not find any strange noises on the speakers, remove them one by one and test the set on high volume.
Never - attempt to disengage the protection on this amplifier. The only times we have found the amplifier to be defective with this protection error, it has done so no matter the volume level. Therefore I believe your problem to be a speaker or speakers.
Sep 13, 2009 | Sony Audio Players & Recorders
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
