Question about GrillPro 20590 22-1/4-Inch Exact Fit H Burner for Fiesta Grills
What are the dimensions ofthe grillpro 20590 - GrillPro 20590 22-1/4-Inch Exact Fit H Burner for Fiesta Grills
Grill troubleshooting
I'll take a shot in the dark that your problem is with how you turn on the gas.
Try this: Turn off the burners and the gas. Wait a minute or two.. Turn on the gas about 1/8th turn. Wait half a minute. Turn on and light the burners.
Hopefully this solves your problem.
Jul 20, 2014 | GrillPro Backyard Grill 5-Burner Stainless...
Contact grill
replacement burners are available and check that the jets are not blocking up. next time buy a stainless steel unit as they last longer. The old cast iron burners have stainless steel burners as replacements now
May 26, 2013 | GrillPro Grilling
I am trying to assemble a grillpro H stainless steel replacement burner 16" model 23515. What does the cross leg for instruction number 2(c) look like? It would help to have a parts list with...
Unfortunately an Owner's Manual or Parts Breakdown for your Model Grill Pro is not available on line. However, you can contact OMC, the manufacturer of your grill 1-800-265-2150 and they can help you.
Thanks for choosing FixYa.
Aug 08, 2011 | GrillPro Grill Pro 23515 1512Inch...
Purchased a grillpro 3 (three burners plus side burner) from orchard. They installed but side burner will ignite. Igniter is working and I hear gas when I turn the burner knob. Fire the igniter and it will...
You're getting gas to the burners, just not enough to ignite the burners.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank.
I hope this helped you & thanks for choosing FixYa.
Jul 28, 2011 | GrillPro Grill Pro 80016 Hose and...
The sound from my dell dimension 9200 has just gone
Try reinstalling the drivers if that dont work try recovery ofthe disk
Jun 07, 2009 | Dell Latitude D600 Notebook
GRILLPRO 45,000 BTU, HARDLY WILL RUN, NOT A LOT OF FLAME
The gas burner needs to be scrubed to open the holes again. The transfer bar that lights the outside burners needs to be cleaned also. Make sure the tank is not cold and there is plenty of gas. Make sure the valve is all the way open on the tank. Its not a regulator problem if one of the burner lights and the others don't. Usually if you barbacue a lot the sauce drips down an creats crud on the burners. Just use a wire brush on the burners. You may have to take them out to scrub them good.
Apr 30, 2009 | Brinkmann 810-2300-B Grill
Grillpro model # 236464 owner's manual
Don't buy GrillPro grills they are junk!!!!!! I have had a GrillPro Model #236464 Stainless Steel Grill and after Three Seasons it has rusted to peices!!!! All Three burners and all Three Flavor Guards and both Channel Cross lites have rusted to a big pile of rust peices. I called GrillPro which is Manufacturered by Onward Manufacturing Company Limited in Canada and all of these pieces have been on back order for over a month and the company says they don't expect the parts anytime soon. Onward Manufactures the following brands:Broil King, Broil-mate, Sterling, Barbecue Genius and GrillPro. I have looked at several of these brands at Menards and they all use the same type of Burners and Flavor Guards that are in my grill so unless you want a big pile of Rust after three years of use I would avoid all of these Brands!!!!!! Forget the problems Take it back where bought and buy something else!! These brands will let you down! Al Gavin - 515-238-3920
Sep 17, 2008 | Brinkmann 810-2300-B Grill
GrillPro 20590 22-1/4-Inch Exact Fit H Burner for Fiesta Grills Logo
73 people viewed this question
Top GrillPro Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a GrillPro Grilling Expert? Answer questions, earn points and help others
