Question about Polk Audio DSW PRO 600 Subwoofer Speaker
Onkyo 591 subwofer green led on no out put - Polk Audio DSW PRO 600 Subwoofer Speaker
I do not have the remote to my lg bluetooth soundbar subwofer anymore and they arent pairing can you help please
Press and hold PAIRING in the back of subwoofer for more than 5 sec,
until LED on subwoofer blinks red and green alternating.
Unplug the power cord of the soundbar and the wireless subwoofer.
Connect then again after the LED of the main unit and the wireless subwoofer fully turned off.
Jul 06, 2017 | LG Cell Phones
My onkyo ls3100 wireless subwoofer cannot connect to controller? and the bluetooth no blinking? no led lights
Hi Reagan, I am sorry about your issue. Please unplug the unit for 30 seconds and try again to pair to the sub woofer. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo Audio Players & Recorders
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
What is the buzzing in my subwoofer?
It has being a long, long time since I've work with a subwoofer.
Check to see if it's making ground inside the subwoofer. Not sure if this will fix it, but it works in mine.
Dec 19, 2015 | Audio Players & Recorders
I need the switch in the handel on the little green machine model 1400 J04336 When I put this in they say it can't be found
If you go to this URL:
http://www.vacpartswarehouse.com/Bissell-Little-Green-Models-1400-2-1400-5-1400-H-1400-U-s/591.htm
you will see an exploded view of your unit and see the switch and associated part number.
If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you! Paul
Oct 07, 2010 | Bissell Vacuums
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Dec 06, 2007 | Onkyo TX-SR605 Receiver
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
Polk Audio DSW PRO 600 Subwoofer Speaker Logo
46 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
