Question about Homedics AR10 Air Purifier
How to reset homedics AR10 - Homedics AR10 Air Purifier
2 Suggested Answers
SOURCE: Homedics AR10 Air Purifier - Clean filter light issues
Please do search before asking question. This one was answered only 20 days ago: http://www.fixya.com/support/t10714206-need_reset_homedics_hepa_air_cleaner
Posted on Nov 26, 2011
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
Is there a recall on homemedics hepa air cleaner
Wow, scary!
no, there doesn't appear to be any recalls and all the reviews are good.
The HoMedics True HEPA Air Cleaner Recalls - Google Search
Jun 05, 2017 | Air Purifiers
Need to reset my homedics hepa air cleaner
Press the lit reset button indicator and hold it for some time (I think it's like 5-6 seconds at least)
Oct 24, 2011 | Homedics AR10 Air Purifier
I have a 'homedics AR 20' air purifier, I have just replaced the filter, and do not know how to get the 'clean filter' indicator to turn off. According to the instructions, there is a...
Hi, I had the same problem until I realized that the bottom is the clean filter indicator just press it down with something and it will beep. I hope it help.
Sep 06, 2011 | Homedics Air Purifiers
Ecoquest air purifier
i have a ecoquest, what you need to do is push the reset button AFTER cleaning. and the preform cleaning will go away.
Jul 22, 2008 | Ecoquest Air Purifiers
How to "reset" the carbon filter dirtiness scale?
Make it holding the button between 10 & 15 seconds & it works. THANKS
Jun 05, 2008 | Kenmore 335 CADR Air Purifier
Reset filter
The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
May 14, 2007 | Kaz Honeywell Tower Air Purifier with IFD...
Homedics AR10 Air Purifier Logo
63 people viewed this question
Top Homedics Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Homedics Air Purifier Expert? Answer questions, earn points and help others
