Question about Samsung Remote Control AQB12JJWC/KCV p/n:DB9303012K
What is the air conditioning picture on a samsung db93-03012k remote
FixiaI need the code for the remote control SAMSUNG AIR CONDITIONER MODEL SH12ZB9.
hi if you input all the details on the internet the name and the model number it will bring up any relevent sites or type in code number for the remote for your unit and it normally brings a list of codes for different air conditioning units it should be there. Good luck .
Aug 04, 2014 | Samsung Heating & Cooling
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
Too much bright
there are controls in remote by which we can decrease the brightness. u did not mentioned if they are working. try to decrease brightness by pressing the menu of remote & going to picture controls & find brightness control there.
if above function not controlling the brightness of tv, there may be fault in lcd panel of your tv. which may be diagnose only after seeing exact condition of picture.
Sep 03, 2011 | Samsung LN32A330 32 in. LCD TV
I need download the user guide of Mitsubishi rkn502a remote control
Search Results
    [PDF]user's manual mitsubishi daiya room air ... - 3D Air Sales Ltd
    www.3dair.co.uk/DOWNLOADS...manuals/O&M%20RAC%20-%20SR...
    MITSUBISHI DAIYA ... performance, read and follow this User's Manual carefully before using your air condi- ... Operation and indication section for remote control . ....Symbols which appear frequently in the text have the following meaning:.
    Air Conditioning User Manuals - Mitsubishi Electric Australia
    www.mitsubishielectric.com.au/Air_Conditioning_Use...
    Mitsubishi ElectricUser Manuals/instruction booklets (including remote control instructions) forMitsubishi Electric Air Conditioners. ... Air Conditioning Downloads ยท Residential Air ...Need to know how to operate a Mitsubishi Electric air conditioning system?
    Remote Control Symbols - Mitsubishi Electric
Aug 20, 2010 | Heating & Cooling
Samsung Remote for my Air condition/ heater unit no longer works
I would post this question in the electronics section. Some of those guru's may be able to guide you through fixing it. Have you actually called the manufacturer about the remote? If so then try to google the unit to see if someone out there may have a few tucked back somewhere. Other than that, there isn't much you can do.
Mar 23, 2009 | Samsung Heating & Cooling
Code E1 on my Samsung AW1204B Air Conditioner
Found this on Samsungs site.Hope it helps a little, at least you know the problem now.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Feb 03, 2008 | Samsung AW1203B Air Conditioner
Samsung Remote Control AQB12JJWC/KCV p/n:DB9303012K Logo
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
